2010 head casket
swagbanker
01-05-2008 08:39:54
How much trouble is it to take the head off and check head gasket issue.
msb
01-05-2008 12:29:02
 Re: 2010 head casket in reply to swagbanker, 01-05-2008 08:39:54
Also be sure to take only the head and not the sleeve deck or you will have a mess on your hands. You should be able to see two gaskets spaced about 3/8" apart. Its the top one you want to take the head off at.
Dale B
01-05-2008 11:02:10
Jes take off all the stuff that is attached to the head and stuff thats in the way , and then pull the head bolts . If the injectors stick out below the head , set it on a 2X4 so they don't get damaged.
