70 Gas Pistons
super99
01-04-2008 16:35:29
From my post a week or so ago, here is an update. I took the block out and took it and the pistons to machine shop for them to check them over. The block had about .0025 wear and he said it would bore out to .0045 OK. Then the parts guy called and said that they can't get pistons. They had quoted me a price of $185/ hole for pistons, rings and pins. He said he called back to order them, and was told they were not available anymore. He said you just quoted me a price a week ago and they said whoever you talked to was wrong, can't get them. SO, I have to get pistons now. .0025 is too much wear to put standard pistons back in , Right? I would think so. Oppy had a set of slightly used .0045 pistons for $250, that is looking pretty good right now. They double checked on the gaskets and they can get a set of gaskets for about $70 but no crank seals. The rod bearings are standard, and had .0004 clearance. The machine shop can get standard, or .0010 bearings. Would one set be too loose and the other too tight? Then I'd have to have the crank ground for new bearings. I'm starting to wonder about my sanity for doing all this. After this is done, I still need a new flywheel and then need to seriously look into new rear tires. Can you say money pit? Chris
super99
01-05-2008 02:19:22
 Re: 70 Gas Pistons in reply to super99, 01-04-2008 16:35:29
Sorry about the decimal point, yes, it is 25 thousand's. The top ring groove is burned off of both pistons, thus the need to replace pistons. My original intent was to ring it and put back together. The compression was so low, you could barely get it started. Want to use it to pull a 440 gal sprayer and a 4 row planter, maybe go to a antique plow day if there is ever one close to home. I have looked at the pistons on this site and might go that way. Wasn't sure, but thought that 25 thousand's might be too much wear for standard pistons, but if the pistons had been good, I would have put new rings on and never checked amount of wear, just reamed out small ring groove at top of cylinder and put her back together. Think I answered all your questions, sorry, I should have put more background into post. Thanks for the reply,s, Chris
Mike M
01-05-2008 06:23:50
 Re: 70 Gas Pistons in reply to super99, 01-05-2008 02:19:22
With that much wear the top rings will flex and break with use, again you will have the same problem. Anyones guess as to how long ? You will be much happier boring it out and going with the oversized pistons and rings. This will give you a much better longer lived job and let you use it for the chores you want without worry. If this site has them then likely they are the same ones others are selling as I doubt too many are makeing them.
Mike M
01-04-2008 20:06:49
Let me try to post again. First time server went down or something ?
I pretty much agree with what the other guy said about .004" being good on rod oil clearance. Alot of machine shops don't understand these old JD's. They are large slow speed engines and do not require the tight clearances of a car engine. Why did you tear it down ? alot of blowby ? with .025" cly. wear that's alot if you are going to use it much. You might get by for parades or shows with new rings and pistons with good tight top ring grooves or ring spacers added.
Hinrich's Repair would be a good one to call about pistons. I don't have his number handy but he does or did advertise in greenmagazine. Shopping around is always a good idea. It does take alot of time and money to get these tractors back into good shape.
Will P
01-04-2008 18:45:05
Super99, I think you have your decimal in the wrong spot for everything????? Cylinder wear at .0025 That is 2 1/2 thousands. Are you trying to say 25 thousands??? that would be .025 I take it they have 45 thousands over pistons? .045?? Rod clearance at .0004 is way too tight, you saying 4 thousands??? .004??? That is fine. Make sure you put the decimal in the right spot, or other wise we will have a hard time helping.
Will
BLinWMi
01-04-2008 16:58:06
Just curious, were you able to do a compression test before getting in to the engine? Being familiar with a 70, if it had good compression on both cylinders, unless you are going to restore it, I would put it back together and use it. After 53 or 4 years of use and the cylinders only have 25 K wear, I bet you can not use it enough to get to 45Ks wear in your lifetime. I know it seems like you will have to dump a pile into this tractor, but just like I did when I got into mine, I had to realize that the 70 is one of those tractors that is rugged to a fault. If it is lubricated correcly, they are almost bullet proof. Maybe it is just overbuilt for the power but they are pretty rugged.
Oh don't know if you saw but this sight has the 45 K pistons kits for $445. I would go this direction over used pistons, by the time you buy the used pistons and the new rings, you are almost at the cost of new ones. And you mentioned needing a flywheel, you never know where and what a good used one might be had for. I bought a good one for mine, just as a spare incase I ever need one, on ebay for less than a hundred bucks. Just wish I had bought the starter from the same guy that ended up going for $26.
