4010 vs 4020
wannafarm
01-04-2008 04:18:33
my dad and uncle had a 64 4020 and our neighbor had a 4010 turbo and lots weights on it, they pulled a 6-16 as did we but they seemed to have more power. they always said the tractors were the same except theirs was overfueled. just curious what was the actual diff in those models.It has been a long time ago
duck64759
03-22-2008 22:13:16
 Re: 4010 vs 4020 in reply to wannafarm, 01-04-2008 04:18:33
Originally the 4010 also had a smaller bore but the same stroke as a 4020. By now all the 4010's still running will have 4020 pistons & sleeves in them. Made the 4010 engine the same bore & stroke as 4020 (404 cubic inches).
Mike M
01-05-2008 06:29:14
They had more power because they added a turbo.
5020s rock
01-04-2008 22:13:36
LOL--i was thinkin that, everybody is a badass in sand !!
B-maniac
01-05-2008 09:42:59
 Re: 4010 vs 4020 in reply to 5020s rock, 01-04-2008 22:13:36
Also a 4010 with turbo and weights and the misfortune that someone pulls a 6 btm. with it will surely not be long for this world. Even John Deere has it's limits.
Tom43
01-04-2008 18:03:51
If you were pulling a six bottom plow with a 4020 you were either plowing sand or not going over 3 inches deep.
5020s rock
01-04-2008 17:08:47
hi--good reading, the 4020 is far better,
more beef and many improvements over the 4010.
at that time things were moving so fast, as far as farming and technology. my dad had a problem with the 4010 block, changed the motor and traded
off on a 4020. i dont remember specifics i was 2
yrs old-lol. i would love to see a 4010 pull
6-16s, cool !!
LarrySTN
01-04-2008 14:04:23
You ask what the differences are. The 540/1000 pto is very different and much much better on the 4020, the brakes were improved. The steering was basically identical. The 4010 didn't come with injection advance the 4020 did. 4020 was available with differential lock, 4010 not. As mentioned the axles are larger on the 4020 and internal parts were beefed up. Front engine mounts on 4020 had 4 bolts per side 4010 had 2. The hydraulic pump drive coupling was much improved on the 4020. The hydraulic pump seals were improved on the 4020. This is the quick list of changes.
dandeere
01-04-2008 09:03:58
not sure about turboed but generally the 4010s are better on fuel and more nimble handling , later 4020s with side consel are more comfortable in the field. Dan
jd40an
01-04-2008 06:17:46
We bought our 4010's before the 4020's came out & still have them (both turboed & with a LOT of hrs.) Though there ARE differences in them, (4020's have bigger rear axles & I think a slightly beefed up rear end, among other things), I've always felt that a 4010D is about 95% of a 4020 at only a little over 1/2 the price. They both were/are excellent tractors if not completly worn out, but remember, the early 4010's will soon be 50 yrs old & the newest 4020's are 38yrs!
Brian Bell
01-04-2008 05:27:14
The 4010 was 84 PTO and 71 Drawbar HP from the factory. The 4020 was 95 PTO and 83 drawbar. However, with the pump turned up and with a turbo, the 4010 could be 100+.
msb
01-04-2008 07:46:55
 Re: 4010 vs 4020 in reply to Brian Bell, 01-04-2008 05:27:14
Almost too many differences to list. Lots of small changed and not all were improvements, like loosening the tolerances up on the seat. 4010 seat was a lot firmer.Didn't jiggles as much, but rust on the rollers became a problem. Solution was to not shim the rollers so tight,giving the 4020 a seat that had more sideways movement.Bette(easier) steering on the 4010. Little things like that few people know about.
