1951 John Deere Model B All Fuel Clutch Smoke
Nathan Kapp
01-03-2008 19:13:36
Hello all, I recently bought a restored John Deere B All Fuel from a family friend. Its a great running tractor but I noticed that when Im cutting grass with it (and a #5 Sickle Bar mower) I get a little white smoke coming from the clutch area around the pulley. It is not smoking a lot, but in the summer evening, I would see it when my lights were shining on it. Is this anything to be concerned about.
jd b puller
01-05-2008 10:41:54
 Re: 1951 John Deere Model B All Fuel Clutch Smoke in reply to Texasmark, 01-03-2008 19:13:36
Is your clutch slipping? If the lever pushes in really easy, you probably need to tighten the 3 bolts up a little bit on the end of the belt pulley.
Mike M
01-04-2008 04:43:26
 Re: 1951 John Deere Model B All Fuel Clutch Smoke in reply to Nathan Kapp, 01-03-2008 19:13:36
I have one that has new pistons and all the works does that. Only thing I can figure is the machine shop screwed up and bored it for alum. piston clearance and I have cast iron pistons. It has to get really warmed up and working before it shows up. Really pulls good,but I never did dyno it.
So I doubt you have much of a problem if it runs good.
B-maniac
01-05-2008 09:47:29
 Re: 1951 John Deere Model B All Fuel Clutch Smoke in reply to Mike M, 01-04-2008 04:43:26
Shine lights on a working tractor after dark and you will see a lot of things you would just as soon NOT see!
jason r
01-03-2008 21:13:48
It is most likely engine blowby. Check your crankcase vent pump and breather line coming from the valve cover, they may be plugged up. At worse you will need rings, a valve job and/or a rebore with pistons and rings. try a little thicker oil. It may stop if you use some 20w50 and lucas treatment if you want to save your money. I have a 42 that did the same thing but i put new pistons rings and rebored the engine.
RobMD
01-03-2008 19:26:56
It's either one of two things:
~blowby coming from the engine
~the hot inner clutch disk burning off all the oil splashing out of the main bearing.
in other words, just keep running it... that is, if your oil pressure is okay.
Nathan Kapp
01-04-2008 05:06:35
 Re: 1951 John Deere Model B All Fuel Clutch Smoke in reply to RobMD, 01-03-2008 19:26:56
Thanks for your thoughts. I do have good oil pressure, so Im not too concerned about it. I had a feeling it wasn't too serious. I will check the breather. Thanks.
