Anti freeze in fuel tank 4020
w6tractor
01-03-2008 14:53:03
An older friend mistakenly put antifreeze in the diesel fuel tank of his 4020. It started, but then quit. We have drained and cleaned the tank and replaced filters. Is there anything else to do (look for) before trying to start it?
w6 tractor
01-14-2008 16:58:54
 Re: Anti freeze in fuel tank 4020 in reply to w6tractor, 01-03-2008 14:53:03
Thanks for the help. Drained the fuel tank and lines, changed filters, added new batteries and it started and ran perfectly. A little lucky, I think. Thanks again.
960
01-03-2008 16:05:04
You have a 50/50 here as you can see from the other post. I know of a neighbor who did that to a 3020 and ruined the injector pump as antifreeze does not lubricate. Best wishes and let us know.
RobMD
01-03-2008 15:01:29
crack some of the injectors and bleed all the nasty out.
You should be fine.
w6tractor
01-04-2008 07:08:41
 Re: Anti freeze in fuel tank 4020 in reply to RobMD, 01-03-2008 15:01:29
Thanks for the response. I'm on my way out to try it. I'll let you know the results.
msb
01-04-2008 07:53:07
 Re: Anti freeze in fuel tank 4020 in reply to w6tractor, 01-04-2008 07:08:41
If it were mine, I would pull the injection pump now. Take the governor housing cover off and completely drain the pump cavity. Then pour the inlet full of fuel and turn the pump over by hand until clear fuel comes out the ports and pray the head and rotor doesn't seize and twist the pump shaft off.
