810 plow
RwE NY
01-03-2008 13:16:57
can any one tell me the rear wheel spacing i need on my A for a two bottom 14" model 810 plow. thanks. ralph
machinery-man
01-04-2008 06:27:37
 Re: 810 plow in reply to RwE NY, 01-03-2008 13:16:57
I also looked in an 810A book and this seemed to be the correct procedure...they referred to similar measurement. Tire size not a factor. One would want a full bite of the plow...I know a good tail wheel or landslide is a factor. Good luck, Chuck
bbaro
01-03-2008 13:44:35
Ralph, for 14-inch plows set rear tractor wheels at 53 inches, centered, from inside to inside of tires, regardless of tire size. This is out of ops. manual OM-A50-574. good luck to you, brian
Handsome Jim
01-13-2008 07:27:09
 Re: 810 plow in reply to bbaro, 01-03-2008 13:44:35
No
machinery-man
01-03-2008 13:43:30
There is a post a page or two back, help me identify this plow and It is a 810 hooked to a tractor. I would think 14" from the center of the front plow might be the spacing for the tire. If you put the plow on the tractor you should be able to see the cut you would need for the tire to ride in the furrow...I"ve got a book but it doesn"t exactly show this. I know I had a 520 and ran the axle out 5 1/2 inches on hub and it worked okay...as long as you got a full bite and tractor ran smooth you"d be okay...tire width ie will also be a factor. Probably a little trial and error needed...
RwE NY
01-03-2008 15:05:00
 Re: 810 plow in reply to machinery-man, 01-03-2008 13:43:30
Thanks guys.
ralph
