brians from SD
01-03-2008 11:27:30
I am in the final stages of restoring a 1939 B. On the last day of 2007, and with not much effort, I was able to get the engine running. I was amazed at how well it ran, because this is my first restoration. Since, I didn't have coolant in the system, I only let it run for a minute at the most. While running, I checked oil pressure which showed between low and medium. I understand that it would be about 10-15 psi, which is about what an early styled B can deliver. The next day I put in anti-freeze, and wanted to start it up again and let it run longer so that I could adjust the idle/load screws, and if nothing else, just to here it run. This is where the plot thickens---I tried to turn it over. It turned over easy, but I could never get it started. It would try to fire, but not enough to run. Since it was colder than the day before, I figured I didn't have it choked enough. At this point, I probably had it 'flooded'. Just like that, and I mean just like that, it began turning a lot harder, even with the petcocks open. I tried about 5 or 6 spins, but to no avail. It had 7 quarts of new oil, so please; nobody try to ask me if I had oil in it. I am looking for advice, where to start checking and what to take apart first. I took off the fan shaft to make sure that there wasn't a drag on that, and it spins freely. The block, and head have been professionally restored, so now I am wondering about push rods, cam followers, or something in the oil pump drive, just to name a few things. It seems like there is a bind somewhere. Needless to say, since it turns over hard, it doesn't swing fast enough to get it stared either. Does anybody want to take a 'stab' at what could be wrong?
