4030 starts then stops
side walk KC
01-02-2008 16:45:49
I just got done rebuilding motor piston, sleeves, bearings, etc.I started the tractor, ran good for about 15-20 minutes then stopped. I restarted it and ran fine again, drove it 100 yards the did the same thing, but started to slow then died. Now only starts with starting fluid. Oil pressure, temp good. Any ideas?
john48jdb
01-03-2008 04:46:10
 Re: 4030 starts then stops in reply to side walk KC, 01-02-2008 16:45:49
look for a restriction in the line going from the tank to the filters and to the pump. boys working for me once lost the fuel cap so they stuffed paper towels in the hole. they fell into the tank and the boys didn't tell me. fianlly one did after we kept having trouble like your describing. tanks off turned upside down and flushed out and it ran fine after that. kept having trouble with the fuel not feeding from one tank to the other (574 ih diesel). turns out that there is a specail order that the hoses on it have to be in. they have a certain hole in them for a specific hole. didn't pay attention to how theycame off and it gave me fits for years. finally a parts boy told me what was wrong. check out your lines to see if they are not stopped up with something. any rubber hoses in the system can deterioate from the inside and cause a flap to hang down and cause the problems like your describing.
Tx Jim
01-03-2008 03:48:10
 Re: 4030 starts then stops in reply to Roger Reinholdt, 01-02-2008 16:45:49
Remve fitting in Inj. pump that return line attaches to and try to start. If it runs correctly look inside fitting for black crude. These fittings can be tricky to clean as there is a glass check ball in them. Also be sure return line is open to fuel tank. Tx Jim
DUCK BILL
01-02-2008 18:36:03
i guess its a diesel? if it is and you can start it make sure return is open on fuel pump, injection pump that is, your return fitting in the pump will sometimes plug up and build pressure inside pump and tractor will slow down or even die you can loosen two screws ont he side of pump as it is starting to die down and release the pressur ethat will tell you if this is your problem, if fitting is pluged probably need govener ring in pump, also be sure your getting enough fuel to the pump , blow thru the line maybe restricked..
wolfman
01-02-2008 17:52:25
Could a fuel line (or return line) be leaking a tad? When it quits, check for air- bleed the system and see if you get air and see if it starts properly right after bled.
lonzo
01-02-2008 17:39:49
Is the enging loosing rpms then dieds and after it cools for a while you can start it again? and is the starter draging, this new fuel we have now is not for yesterdays tractors. I have had problems with pump and injectors because of the diesel. happy hunting
side walk KC
01-02-2008 19:44:40
 Re: 4030 starts then stops in reply to lonzo, 01-02-2008 17:39:49
this is exactly what is happening any ideas to fix
RobMD
01-02-2008 17:04:28
Lets see.. IF you're using starting fluid on a tractor with a rebuilt engine, something's obviously wrong. What did you do to the injectors? How about the Pump? did you replace the fuel filter? How about the fuel shut-off solenoid? These can go bad causing the fuel to shut on and off intermmittently.
