346 JD baler
John
02-05-2000 17:13:02
Looking for ways to modify my 346 JD baler for higher output any suggestions would be appreciated thanks.
Gordon L Hardy
05-19-2005 19:46:26
 Re: 346 JD baler in reply to John, 02-05-2000 17:13:02
Is possable to get a part manual for a 346 JD baler?
207-778-4012
twopop
02-05-2000 17:52:57
the only way i can think of is to increase the strokes per minute. what kind of deere are you pulling it with? does it have a 1000 rpm pto? you baler runs at 540 pto speed if you can change speeds such as with a 4020 you could speed your baler up by running say 650 pto rpm.
John
02-06-2000 17:01:14
 Re: Re: 346 JD baler in reply to twopop, 02-05-2000 17:52:57
Thanks twopop for reply. The new 348 balers run at93 strokes per minute with a 295 pound flywheel. My 346 runs at 80 strokes per minute with a 263 pound flywheel.The Newholland 320 runs at105 strokes per minute.The new holland also has more rollers on the plunger head then the JD.My question is how many strokes per minute do I dare run my 346 before it flys apart.Should I increase the weight of flywheel to 300 pounds? Thanks for taking the time. John
