For those of you who missed my misadventure....I let the flywheel on my 70 diesel get loose, and it was knocking REALLY bad. About a month or so ago, I found a used taperlock flywheel, in good shape, and locally, so no shipping costs either. I got a good deal! So I've been slowly working towards getting the beast running... Here it is in my carport, as I work on it at night. I'm a second shifter...it seems I can only get motivated to work only after the sun goes down and it's freezing cold, with snow?
 I had to file the splines down to get the slinger off! I replaced the broken thrust washers and then added shims to get .008 of endplay.
I rolled the taperlock in the shed and tacked on a new ring gear that I already had. Note the snow on the flywheel. My dad wasn't happy with my Mig-rigging, so he tacked it later with a stick welder.
About a month after the above pics... Yesterday, I finally got the taperlock on the crank. But I failed to find the proper timing marks and put 'er on wrong. Yes, I'm dumb. She had a pretty good shake.
So I had to get it back off. What a pain in the butt. Tools all over! No, I didn't use the torch, it was just in the way.
Of course, it wouldn't come off without a fight. Had to make a puller out of some steel lying around. But instead of pulling...it was BENDING. I gobbed on some angle iron and it worked. Yes the welds are horrible, but I don't do it for a living!
Got it on correctly this time. Note the V on the crank lines up with the indent in the taperlock sleeve
So now the tractor is FINALLY running again! Note the smoky atmosphere and standing rain cap!
Oh, for you video people, if you want to see it and hear it running...here ya go! Yes, it is 20 degrees. Gotta love those little V-4s, started up with no trouble after sitting for three months. I didn't get it running 'til 11:30PM
I don't know if the flywheel guard will rub or not. I think the flywheel is about 1/16 an inch or so farther out? I'll shim the guard out if I have to. I don't know if I have enough motivation to remove everything AGAIN to grind material off the inside of the sleeve. Oh! What about the OLD flywheel you ask? It has a new (and important) job...as weight in the back of my dad's truck!
 Brandon
