JD 1050 clutch slipping
cdv
01-01-2008 14:41:18
messing with adjustment for 3 days, got 1 inch freeplay ,clutch lets off at 1 inch from top of petal ,today I hook up to the trailer let chutch out and tractor bearly moved after a bit it started takeing off but slowly like clutch is slipping tractor has 360 hr clutch petal had no freeplay when i got 3 weeks ago thanks cdv
leon
01-02-2008 05:20:50
 Re: JD 1050 clutch slipping in reply to cdv, 01-01-2008 14:41:18
Any sign of engine oil dripping out the bottom of the clutch housing? Is it possible the engine's rear main seal is bad and the clutch has oil on it?
Kemper
01-01-2008 15:15:49
If it had no free play when you got it and had been run like that very long at all ,then your clutch is shot, as long as it has an inch or so free play thats all you can do as far as adjustments, plan on getting a new clutch installed.
