4430 starting troubles
Meatcutter
01-01-2008 11:37:46
'73 4430 Both batteries test 6 volts. From the starter post to ground tests 12 volts. When I try to start tractor, it just clicks and won't turn over. If I use a jumper from my truck it will turn over after being hooked up for about 10 minutes. What seems to be my problem? Thanks
Texasmark
01-02-2008 07:21:40
 Re: 4430 starting troubles in reply to Meatcutter, 01-01-2008 11:37:46
I bought a 4230 a few years ago and it had two large 6v batteries wired in series; one on each side, in the OEM batt boxs. I don"t like using ether to start so I was looking for a better mousetrap. Besides, ALL the 200-300 amps starting current had to make the loop across the tractor to the other side and back. Not good when you only have 12V and want to get 11 of it on the starter if you can.
Problem with 2ea 6 volts in series also is that the current that the starter uses has to flow through the internal resistance of 2 batteries. Not good for spinning up a diesel.....besides all the wire.
So I got 2ea 950 CCA size 31 (a 27, like for a trolling motor but with 3/8 studs)12v batteries from my local OTR truck dealer (under $70ea) and while I was there I had him make me up a set of 0 or 00 (probably 00 forgot which) wires which allowed me to wire the batteries in parallel. We heat shrunk tubing over the crimp connection to keep the weather out.....just like the boys with the big rigs do!!
I connected the battery on the right (curb side) to the terminals of the one on the left (putting them in parallel), and since it was right next to the starter, I jumped from there to the starter solenoid hot terminal and ground on the starter bolt to the tractor frame after I shined it up real good. So those short runs (less than 15")of wiring were the only ones that had to carry the full current.
Don"t have to tell you the results. The sucker just leaps to life and have started it down to 20 in less than a minute with no starting aids on #2 diesel, cause we get the same diesel year-round down here.
Try it, you"ll definitely like it.
Mark
620
01-01-2008 20:35:31
we had that same problem on our 4430 and determined it was the alternator put a rebuilt alternator on it and have had no problems since.
Sandhills Electric
01-01-2008 16:59:27
If it was me i would go get a big 12 volt or two of them and you will be much happier. I would bet you have a dead battery, good luck!
GeorgiaHayFarmer
01-01-2008 13:18:54
Prop your voltmeter on top of the battery case and start the tractor and see what you get. Check each battery then both and see what happens to your voltage during starting. After your check, charge your batteries for 30 minutes and try again. You should be able to tell if you have a problem battery if under a load its dropping to 1 or 2 volts. Did ya leave some lights on, etc.
Scott
Meatcutter
01-01-2008 13:43:17
 Re: 4430 starting troubles in reply to GeorgiaHayFarmer, 01-01-2008 13:18:54
I found a broken wire on the alt. after batteries went dead. Fixed wire and charged batteries. All I get now is the clicking sound when turning key. I used jumper cables on starter bolt and ground. Still takes five or ten minutes to get the engine to turn over.
BMAN
01-01-2008 12:19:01
Could be time for a rebuilt starter.
rexhellwig
01-01-2008 12:06:11
The voltage checks don't mean much until you check it with the engine cranking. {or trying to crank}
Check a good 4430 with clean, properly sized cables, batteries and starter in good condition.
It will have no less than 9 volts at the big motor terminal on top of the starter with the engine cranking. If yours doesn't, start working your way back toward the batteries until the voltage is 9 or better. I would guess the trouble might be as simple as a nasty connection or a bad battery.
Now that winter is here, starting problems that were marginal before are going to give trouble now. Don't be cheap with batteries and cables on a tractor that sees a lot of winter use. That slow, low voltage cranking takes it's toll on a starter motor over time.
