G---?
MTC
01-01-2008 04:33:43
Happy New Year guys-have a guy who wants to sell me a 1948 John Deere A.Went to look at it and no serial tag.It looks alot bigger than a A and I think it might be a G.How can I tell?Any advice would be appreciated.Mike
F-I-T
01-01-2008 10:36:14
 Re: G---? in reply to MTC, 01-01-2008 04:33:43
Some points covered by others, but a "G" will have the narrowed front frame to accommodate the standard front mounted cultivator width, the exhaust and intake across from one another, probably a 4 post steering wheel, a crankcase vent pot on the crank cover, but if all else fails.....most of the casting numbers will start with an "F" since the "G" was originally going to be called the Model "F".... ;>)
HTH
Frank
skip33652
01-01-2008 06:40:10
just look at any casting head block crankcase whatever and find casting # an a will have an A prefix. a b will have b prefix. a g will have f prefix. a d a d prefix. and a gp a c prefix. example a59r would probably come frome an a tractor d2r comes frome a d.Paul
P Browning
01-01-2008 06:27:15
Model G tractors will have a weldment of angle iron for the front end support frame while the later (early 47-up) Model A has a pressed steel one.
Also -- the front end support will narrow toward the front once forward of the cylinder head - this so as to accept front end equipment like cultivators used on Model "A" tractors.
Check intake and exhaust stacks. For all styled tractors, for the "A", the two are in-line (centered) while for the "G" they are one on each side, across from each other. (PatB)
MTC
01-01-2008 05:12:02
Geez- look at the air cleaner pipe and exhaust pipe.Answer my own question.Another question would the 1948 A work on a John Deere 7000 4 row corn planter?Would the hydralics lift the planter when it is full of fert.?Thanks guys
BLinWMi
01-01-2008 05:48:18
 Re: G---? in reply to MTC, 01-01-2008 05:12:02
Well it would but not very well, it isn't heavy enough for one thing and just wouldn't have the horse to pull the planter at any speed. I used to have a 4 row W 7000 set up with liquid and pulled it a couple times with the 60 but it was much more suited to the 3020. Now the old 494 4 row, the 60 was a great tractor to pull it with but the 7000 is alot more planter. I have no doubt the hydraulics would lift it, just not real fast, I always liked to flip the lever on the go and never have to stop, might not be able to do that with the A. Well thinking about it, the speed the A is able to pull the planter, maybe you could lift it on the go. But you would definately need some more weight on that tractor to be of much success.
MTC
01-01-2008 05:11:56
