Inner weights on 820
toolz
12-31-2007 21:03:45
My recently aquired 820 has big inner weights on the rear hubs. About how many pounds are these? I'm wanting to keep the total weight at 10,000lbs or less, and I really don't want to pull the hubs and take the weights off. Thanks- Kevin
David from Kansas
01-01-2008 17:08:50
 Re: Inner weights on 820 in reply to toolz, 12-31-2007 21:03:45
Toolz,
I just recently pulled the rear cast centers off an 820. One came off pretty easily, the other one was a real bltch! Took a 20T and two 12T hydraulic jacks to get it loose. I have axles and what looks to be very good bearings if you are interested.
magg
01-01-2008 04:52:44
My 820 also has cast inter weight that have to go... man that I bought it from thinks they weigh about 450lbs each..M
BLinWMi
01-01-2008 05:40:23
 Re: Inner weights on 820 in reply to magg, 01-01-2008 04:52:44
Are your cast hubs 30" or 34"? I might be interested in buying a set of these inner weights if they would fit the hubs for 30" tires. I need more weight on my standard without calcium.
toolz
01-01-2008 09:34:12
 Re: Inner weights on 820 in reply to BLinWMi, 01-01-2008 05:40:23
My hubs are 34". I'll have to measure to see if they will fit 30". I thought the weights were 450-500 lbs, but not sure. Dry weight on the tractor is under 8000 lbs, so I should be well under 10,000 without calcium. Since the tractor is partially apart, I can't scale it. I need to replace a rear wheel bearing, and may not be able to get the hubs off the axles. The axle may have to come out with the hub on it. I sure don't want to pull the axle again to get the weight off. I'll start another thread asking scale weight of some 820's. Thanks for your input. Kevin
RobMD
12-31-2007 21:38:20
if they're the correct ones, they're 150 pounds apiece. Someone prove me other wise here?
RobMD
12-31-2007 21:38:04
magg
01-01-2008 16:47:18
 Re: Inner weights on 820 in reply to RobMD, 12-31-2007 21:38:04
The outside bolt on weight maybe 150lbs. but he's talking about the inside weight ..mine is in a 34 in. wheel & is at least 12in. thick & fills the entire wheel rim to axle...parts book list them at 450....as soon as I get these out I will give them away...take care
