starting JD D
bigtim72
12-31-2007 18:57:11
just got my 1932 D put all back together today but could not get it to run I primed it with gas and fired a couple time but would not take off and run it has a wico base mount mag so no way to retard the spark but has real good spark at plugs and when i try to choke gas comes back threw carb. so i think its getting gas I put new rings in it so should have good compression cause it really wears me out turning that flywheel thanks for any help and Happy New Year
John T
01-01-2008 09:52:32
 Re: starting JD D in reply to bigtim72, 12-31-2007 18:57:11
Tim, Im NOT a D man buttttt ttt if its not kicking the flywheel backwards when you try n start it like when its start/impulse timed too fast/advance, I DOUBT IT NEEDS TO BE RETARDED, BUT IT MAY ACTUALLY NEED ADVANCED SOME ?????
You can indeed advance or retard the start/impulse timing and the run timing on the base mount units, the coupler to the mag drive ought to have bolts you loosen n turn to do that. Also the mag has an adjustable impulse stop plate to adjust start/impulse timing seperately.
If its NOTTTTT TTT one of the Edison or Splitdorf or type mags with the lever to retard the start timing but a Wico C or X base mount, set the start impulse timing so she snaps n fires right at TDC or maybe 1 to 3 degrees BTDC but never afterrrrr rrrr. If its the other adjustable retard lever mags with the flywheel with the Left Hand Retard instead of teh left hand impulse, Duane posted Glens method of timing them a week or so back.
Of course, she cant be timed that 180 out thing like where on the Wico C or X a plug wire swap cures cuf if shes 180 out it can pop n bang n backfire n maYBE kick the flywheel back somethign awful
John T
Bobl1958
01-01-2008 05:51:16
I believe there should be a coupler between the mag and the mag drive off the governor. Loosen the 2 bolts on the drive coupler and the 2 halves should turn to retard or the other way to advance. Manual should show you how if you have an older D manual. I'll look in one of my manuals to see if it discribes how to do it. You need to check the timing with the flywheel hash mark to see where you are at. Probably, though, you just need to give it a pull or belt it up to another tractor.
RobMD
12-31-2007 21:17:31
Even If you can't get it started, take pride in your resultant "body builder" physique.
old
12-31-2007 20:58:56
I just hauled in a 1935 D and I figure the first time it runs it will be pull started. I know with my disabiltys there no way I will start it the first time if even after I have it set up right.
MSD
12-31-2007 20:21:37
A good log chain works best. I hade two of em and it was the same with both.
