4020 block
Scott C
12-31-2007 15:42:30
Can anyone tell me if a 4010 Diesel engine block will fit in a eraly 4020 diesel tractor? Its looks to be the same block Butt I am not sure.Thanks for any help, Scott.
minor1977
01-09-2008 20:17:41
 Re: 4020 block in reply to Scott C, 12-31-2007 15:42:30
will probably fit but is a lot smaller displacement engine (369 ci instead of 404). I do believe you can put 404 sleeves and pistons in it though.
LarrySTN
12-31-2007 17:28:35
The 4010 block will bolt to the bellhousing. The difference is, the 4010 has two bolt holes in the boss that bolts to the frame rail at the front of the block whereas the 4020 has four bolt holes at the front. I don't remember if the bolt holes on the front of the 4010 block aligns with the 2 of the four holes in the 4020 frame rail.
matthies
12-31-2007 19:23:03
 Re: 4020 block in reply to LarrySTN, 12-31-2007 17:28:35
The holes will line up. The engine stand we used at the dealer had the same mounts that bolted to a 3010 engine and 619's out of choppers and tractors. chris
