Fuel Lines H
Walter Squires
12-31-2007 13:30:00
Holy moly have you priced a set of fuel lines for an JD "H" about a hundred and fifty bucks at the dealer, anyone else sell these aftermarket?
davr101
12-31-2007 17:34:48
 Re: Fuel Lines H in reply to Walter Squires, 12-31-2007 13:30:00
I just put a three-way fuel valve back on my H and I made all the fuel lines. The only one that was an issue was the one from the main tank outlet on the fuel valve to the carb. The nut on the carb and the original fuel line was larger than the new nut and the new fuel line. The carb fitting can't be changed to match the fuel valve because it is a special fitting. I simply cut the old line off about 2" from the nut and drilled out the tubing some. The new line slid right into the section of old line I cut off and I used a propane torch and solder to seal it. Looks and works great. I need a new fuel line for my M, but why pay so much when you can make them so easily for a fraction of the cost.
jdhbag
12-31-2007 17:18:42
Sharps has them for $25.00 each. Go to www.oldjd4u.com. Look on left side and click on fuel lines.
Mike M
12-31-2007 16:33:15
I have made several fuel lines for various models by either using oil lines from the insides and rebending them or cutting off the ends and drilling them out in a lathe and then solder in new pipe. I had a good supply of used oil lines from parts tractors.
Paul from MI
12-31-2007 13:34:40
Make your own. You can buy gland nuts & ferrules from oberts or Detwilers. Just get some 5/16" copper tubing, bend to fit, and solder on the ferrules. Easy job and looks good.
Paul
