Dynomometer results
David Snipes
12-31-2007 12:52:39
I recently bought a John Deere 1640 from a dealer who got it used from Canada. The manual says it has 62 pto HP. During its life with the Canadian farmer, the same dealer put it on their dynomometer twice over several years. The first reading was 72 HP, the second was 80 HP. Has anyone experienced similar discrepencies? I wonder if the dyno's vary a lot over time and between brands. The 1640 uses the same engine at the 1840. I assume their only diffence is in tuning. Maybe I got lucky and they put in the wrong engine.
rexhellwig
12-31-2007 15:37:22
 Re: Dynomometer results in reply to David Snipes, 12-31-2007 12:52:39
Sure. It's possible that the pump "screw" has had some tuning.
But it's more likely the discrepancy is the "nut" running the test. Take your tractor to the nearest dyno. Whatever the power reading is, I would almost bet it anything other than 62, 72, or 82 hp. You would be surprised how many shops can't get repeatable results within the range of allowable test error.
Heat Houser
12-31-2007 14:58:41
A common misperception in doing a dyno test is to continue to load the tractor below rated RPM and then take the hp reading. (mechanical type with a hydraulic load cell and pressure gauge readout) The only true test of hp is to take the reading at rated RPM. Horsepower actually drops as the RPM decreases below rated. Torque does go up due to volumetric effiency of the injection pump which squirts more fuel per injection but it cannot make up for the RPM loss. Horsepower goes down as a result.
Is your tractor turning out extra hp? Maybe not if the test was not performed properly.
buickanddeere
12-31-2007 19:41:09
 Re: Dynomometer results in reply to Heat Houser, 12-31-2007 14:58:41
Volumetric Efficiency relating to max torque rpms refers to airflow of the engine, not the injection pumps delivery per stroke. Modern electronic system are often programmed so max fuel delivery varies along with the engine's airflow per revolution. This can be programmed to give the appearance of "more lugging capability".
buickanddeere
12-31-2007 13:40:31
Same 4.19X4.33 239cu" four cylinder and chassis for the 56HP 1640, 63HP 1840 & 68HP 2240. HP is just a turn of the injection pump. Most dealer's dyno's read a bit high because it makes the customers happier. Or was the dyno operator just jugging her down until the psi gauge maxed and didn't maintain 540rpm? The numbers have that kind of look. On of these days I'm going to find the injection pump manual and tweak my 1640 up a couple of notches. Does yours have 4WD, high/low shift, deluxe fenders or rops etc?
David Snipes
01-01-2008 07:16:34
 Re: Dynomometer results in reply to buickanddeere, 12-31-2007 13:40:31
Its 2 wheel drive, has hi/low shift & standard fenders. It spent its entire life on a berry farm in British Columbia and is in pretty good shape. I got all the maintenance & repair paperwork from the same dealer & that shows the two dyno tests. I've had it for 2 years now and it been a great tractor. The only problem it had was the starter shaft bushing broke and cracked the aluminum housing. I had to buy a new starter. That hurt$$
I brought it to eastern Washington. I don't think the poor thing ever saw sunshine. I had to put sun block on it to get it used to our dry sunny weather.
