2750 JD any good?
haysaver
12-31-2007 12:45:31
Looking at a 2750 with a loader on it. Has 3200+ hrs. Has a cab also. Was well cared for and am considering it for a hay tractor. Any thoughts on good or bad things to look for.
low budget
01-01-2008 04:22:39
 Re: 2750 JD any good? in reply to haysaver, 12-31-2007 12:45:31
Have a 2550 and 2755, 4wd with loaders. Good tractors, especially for that type of use. I will admit a 3020 or 4020 makes a nicer tractor for field work, more convenient and comfortable to operate. The weakest point of the JD utility tractors is the low presure (transmission) hydrualics. Mine dont have cabs so I cant comment on that.
ram ranch
12-31-2007 22:51:52
Had one new, last tractor to leave the barn. Hired hands would get in fist fights for who did not want to operate it. They picked a 4020 or 4010 over the 2750. Even a gas 3020 was use before the 2750. Every gear ground when shifting no hydraulic pressure under 1500 rpms, to light of tractor for the horse power. Granted 80 horse turbo charged motor, but not a 4020. For utility work or loader great tractor, but that�s all. Traded for a used 4020 and never thought of it since.
jd2120
12-31-2007 21:30:51
I don't want to be the lone person with negative comments but i know first hand about the 2750. 3 farmers in this area had them, cab tractors and all of them were junk, you name it, it went bad, one motor blew at 1000 hours, never could keep the AC working, tractors always running hot, i used it a few times, once while driving down the road the temp gauge started going back and forth then pegged to the red, which scared me pretty good. I"m sure some people have had good luck with them, but i even heard the JD rep in this area say that was one of the worse tractors JD ever produced.
RobMD
12-31-2007 17:58:12
excellent medium-sized chassis tractor. Nimble and Relatively lightweight for its size.
If you need a Beefier deere, a comparable tractor is the 4050 which has a longer wheelbase and an overall heavy frame
LarrySTN
12-31-2007 17:33:25
I've got one which I purchased new. They are a decent tractor.
