300 (1020) hyd. problems
deereford
12-31-2007 11:20:31
Help, I need a new stroke control valve and seat insert but I can't figure out how the seat insert is removed. I am trying to change it with the pump installed. I tried tapping on it from the top with a small deep socket but to no avail. My repair manual shows and tells nothing. Thank you very much in advance!!!
jdemaris
12-31-2007 17:38:47
 Re: 300 (1020) hyd. problems in reply to deereford, 12-31-2007 11:20:31
Which pump? 1020 has a little German pump. My 300 has the full-sized, U.S. built 2.4 cubic inch pump - and the two pumps are totally different.
The full-size pump has the allen-screw adjuster on the bottom. With that, you reach in from the top with a punch and drive the seat out. The only thing that holds it in is o-ring pressure - otherwise it would fall out.
deereford
01-01-2008 07:51:34
 Re: 300 (1020) hyd. problems in reply to jdemaris, 12-31-2007 17:38:47
Thanks for your response. My pump is the 1.38, at least as far as I can determine. Thanks again.
jdemaris
01-01-2008 09:05:31
 Re: 300 (1020) hyd. problems in reply to deereford, 01-01-2008 07:51:34
I always wondered if any 300s came with those little pumps. All the 1020s have them, but the 300s I've worked on have the bigger US pumps.
If your pump is the one in this pictures, it's the little German pump - regardless if four piston or eight piston. That seat is pressed in - unlike the seat in the big US pumps. You have to drive it out.
third party image
third party image
deereford
01-01-2008 10:05:02
 Re: 300 (1020) hyd. problems in reply to jdemaris, 01-01-2008 09:05:31
Yes, that looks like the pump I have. It's the No. 33 (seat) that seems stubborn. Maybe I need to be more forceful. That seat is only $5.50 at mother Deere but the valve comes up as an invalid number. Perhaps it's time for an entire replacement pump$$$$$$. Thank you again SO much!!
jdemaris
01-01-2008 13:22:41
 Re: 300 (1020) hyd. problems in reply to deereford, 01-01-2008 10:05:02
My replies keep getting deleted and it's getting kind of tiring.
Hopefully I'm not double, triple, or quad posting. These forum keeps deleting my posts when URLs or even the names or certain sites are included. This is my fifth attempt to reply to you.
That seat comes with the entire valve assembly - part # AL71019 from Deere and $81.
It's for sale at half the price many places - maybe even here? I guess I can't mention where. So, just do a Google search with the Deere part # and you find it for $37.
deereford
01-01-2008 17:55:36
 Re: 300 (1020) hyd. problems in reply to jdemaris, 01-01-2008 13:22:41
You are a Godsend to me. I will probably seek you out in the future for great technical advise. I hope somehow I can return the favor. Thanks a million!!!
powertech84
12-31-2007 11:56:02
its probly cocked just a little. if its straight, it will practically fall out. use a 3/8 punch and push from the bottom and then the top till it comes out
