630 Block and Pistons
GlenT
12-31-2007 09:15:49
There was a similar message below from fordtech a couple pages back but I'm not sure whether people read that far back.
Anyway, I bought a set of new NOS high altitude pistons (A5985R) and rings (no wrist pins) last week on ebay. I saw the listing a few minutes before they sold so didn't have time to run out to the barn and see what size I actually had. Well, my good block is already at .045 oversize so I'm wondering whether I should sleeve the block or look for a standard size block needing a bore to .045 oversize? I don't want to put new pistons and rings into the old cylinders and would like to stick with the NOS high altitude pistons because I know the quality is good. Fordtech wanted to know why the largest size Deere sold was .045 oversize? I am also curious about that. What do you folks think I should do?
Thanks!
Waygin
12-31-2007 18:06:37
 Re: 630 Block and Pistons in reply to GlenT, 12-31-2007 09:15:49
GlenT,
Just from my experience.....I have a 620 that has been in the family since new that is bored 0.90 over and yes it does get hot not really overheating but the manifolds do glow cherry red near dark when it is under load, but man does it pull.
machinery-man
12-31-2007 11:24:46
I only have an opinion about the overbore. Believe for hard use the overbore might produce an overheating problem(maybe not), but think about the time frame it would take to wear a block to .045 over and then rebore and wear that out. Maybe Deere thought it would be time for a new tractor by then?
GlenT
12-31-2007 13:21:06
 Re: 630 Block and Pistons in reply to machinery-man, 12-31-2007 11:24:46
Good point about the hours to wear out a standard and .045 bore. The .045 bore is actually pretty good yet, just one spot on the right cylinder where there is a rough spot (looks like rust but may be a broken ring?). I have had the tractor since 2001 and just now getting around to fixing it up (retired and have some time). I drained the anti-freeze and pulled the head a couple weeks ago and there was no anti-freeze in the cylinders so that is a good sign of a good head and block I guess.
I may just pull the head on my 620 and hope it has a standard bore. If it is standard, I'll have it bored to .045 oversize and put it on the 630. The old 630 block and pistons can then go on the 620 with new rings. If not standard, I'll just be out a head gasket when I put the head back on. I want to keep the 630 and maybe sell the 620.
Does anyone know of aftermarket high altitude pistons in .090 oversize if I decide to go that route?
How about sleeves?
Thanks!
fordtech
12-31-2007 10:50:01
Glen,I look on ebay for good parts for my 630 all the time did not see these pistions good find to find a standerd bore block to bore and clean up at .045 I think it might be hard to find one. my block is standerd bore taper is at .009 and .o12 im not sure if it would clean up at .o45. after the holidays the block and head are going to ths mashine shop to be checked for cracks,no sense in spending money boreing a cracked block! lets see if any one can tell us why john beere only listed .o45 oversize does one of you guys know?
machinery-man
12-31-2007 09:24:51
For my money I wouldn't bore out a block. I would find a good used block to accomodate the pistons, clean in up, bevel the ring groove so new rings wouldn't be damaged and go with that. Personally no more than these tractors will be used you'd be good for many years to come.
