paul I bought this tractor with low oil pressure although the previous owner told me that pressure was above L before he changed the oil.. I have removed the case cover and see nothing broken or obviously out of place. I have not yet looked at the oil pick-up screen nor the pump gears. the bottom of the case is not too dirty so don't hold much hope that a plugged screen is the casue of my problem. but I will check. I do see a clean area on the filter housing at its interface with the filter head where there should be no active oil flow to scrub that area clean; which suggests that there might be a leak between the filter head and body as the manual suggests and which would be consistent with the statement that "there was oil pressure above L before the oil chnge"... I will check that out. I will also attempt an adjustment of the oil pressure. I need your help here. there is no guidance on screw direction (cw or ccw)for increasing the oil pressure on the D. an adjustment screw turning direction (cw)for incresing pressure is defined for only certain models of A and B. do I assume that the other models not defined are also cw? It seems logical but may not be so. also, how many turns equals how many psi? I would like to get this adjustment right the first time to avoid getting into the bowels of this engine again. It doesn't appear likely that I will succeed in this. thx for your help. pete
