Another 830 question for F. I.T.
LWS
12-30-2007 19:39:05
I replaced the fuel transfer pump with new seals and I purchased some new outer N.O.S plates and put it back together. The service manual said that you should put a thin coat of shelack between the plates. I used flange sealent instead and it sweats a little diesel now. What should I do to stop this.
Thanks!
LWS
F-I-T
12-30-2007 20:06:33
 Re: Another 830 question for F. I.T. in reply to LWS, 12-30-2007 19:39:05
Take it apart and use some Indian Head Shellac. It doesn't take much goo. Those plates should be really flat. I lap them in and after that I think they would seal without shellac, but I still use it.
HTH
Frank
msb
12-30-2007 21:11:14
 Re: Another 830 question for F. I.T. in reply to F-I-T, 12-30-2007 20:06:33
Listen to FIT. They had shellac on them when new from the factory. Lapping the surfaces is a good practice too. I have had them leak when only using the shellac in years past. Be sure to keep the shellac off the gears and give it plenty time to dry.
