The H242R Cam Gear interfaces with gears of both the crankshaft and governor. The camshaft gear and crankshaft gear are lubricated by splash of oil from within the crankcase. And so "yes", hand-cranking will leave the gear dry for the most part. There also is a trickle of oil coming from the governor in-feed off the oil pump, but this is small in comparison to the feed into each of the mains. This area of the "H" has always seemed to come up just a tad short lube-wise, especially in tractors before H16625. The rub comes in here in that the left-hand camshaft bearing receives its lube mainly from the governor's internal oil line in-feed. For H16625 & lower, Deere furnished a special external oiler to deliver some additional oil to both the governor gear and camshaft's left end bearing. From 16626 - 17580, the internal line to the governor was considered sufficient, but a line continued to be installed from the lower part of the L.H. Governor bearing housing to the camshaft bearing housing. And from 17581-up, some added change (unknown) was realized so that external oiling lines to the left side camshaft bearing housing were no longer used. And yes, all this activity concluded during the 1940 production year. If you have the John Deere "H" Restoration Guide, this oiling system is outlined under the heading of L.H. Governor Bearing Housings of which there were four types! Learn more by a visit to the JD-H Restoration Site (below). If your tractor is 17580 or lower, try to ensure you have the external oiling system in place to help prolong the life of both the L.H. Governor bearing and left side camshaft bearing. See page 9 in your PC304 Parts Catalog for details. The feed to the mains, BTW, is the source of flow to the rods. As for one rod seeming to receive more oil than the other, this can be a function of more wear or looseness on the left side than on the right -- main bearing versus crankshaft. A looser fit will allow oil to make its way back to the crankcase (at the main) without traveling to the rod! (PatB)
