60/620/630 Shifting Forks
Waygin
12-30-2007 18:44:55
Does anybody have the specs for rebuilding the shifting forks for a JD 630? My are badly worn causing the trans to double gear when shifting from high to low side. Would like to build them back up and turn to right dimensions but need to know how much to cut back? Thanks for any help
Mike M
12-31-2007 06:00:31
 Re: 60/620/630 Shifting Forks in reply to Waygin, 12-30-2007 18:44:55
I have done bunches of those up in the area where the shift lever ball contacts. I use nickle rod ,that muggy rod sounds better never tried it. You can see the unworn portion just fill in the low spots and grind it flat and try the shift lever so you don't get it too tight simple as that. Really brings back good shifting. New detent springs is a good idea too. I rarely used to replace them as I thought they would be high priced. Last time I bought some I was surprised at how cheap they were and wished I'd replaced more of them. I had one tractor I had to build up the corner of the shift quadrant tower so the lever stayed on track. I don't think it was ever right from new. Just a little careful trial and error test fitting will show up any problems before you button it up.
Waygin
12-30-2007 18:59:40
Only problem with used sets is the same thing that I am running into already.....they are worn out too. I am setting on three different sets of forks two are worn as bad as my and one someone has attempted to build back up but badly I most admit. One guy that I talked to has tried this with a International with somewhat sucess but never with a JD.
machinery-man
12-30-2007 18:52:47
Have done a lot with forks, replacing. Have replaced some detents, springs but never heard of rebuilding forks. Might put some surface on contact points to ball shifters....I don't know of any specs...I'd recommend getting a good used set....
