Gee that was easy..
scooter01922
12-30-2007 15:35:56
It works... a bit of messing around with it and it finally moves. To those that suggested i check the linkages, thanks. Even though i had already checked everything several times that"s what it was. Specifically it was the pin in the linkage that runs from the clutch across to the reverser. It did have a pin but it was a tad on the loose side. Installed a tighter pin and presto....it drives. Unfortunately the first time i hit the brakes it held for a sec then the petals went to the floor. I just replaced all the check valves in the whole darn brake control valve so i just don"t know. Maybe i"ll just send it off to the friendly service department. On the upside the tractor made short work of the 4 foot iced up snowbanks around the driveway.
Thank you to all
Scott
