435 john deere
Jersey boy
12-30-2007 14:46:14
Found a 435 John Deere with gm motor. It is stuck. The rear rims and tires are shot and the grill is missing. hood is rough as well. Does anyone know what a good market price is for this tractor. Thanks in advance
jd b puller
12-31-2007 16:00:01
 Re: 435 john deere in reply to Jersey boy, 12-30-2007 14:46:14
MSD, probably the easiest way to post pictures is to post them on the "tractor Photos" section. (Left hand side, under Galleries). Then just list the URL in the posting.
MSD
12-31-2007 15:00:32
If I could figure out how to put pictures up on here, I would show you what it looks like when it is completely disassembled. That motor has more parts to it than you would believe. I got mine back together this fall and really like listening to it run. I also added up all the bills last week. Ouch
buickanddeere
12-31-2007 13:46:25
2-53's are a dime a dozen. They need to be rebuilt to N specs up from the S specs or you will hate the thing. Just found out there is another injector with an even better spray pattern than the N or C series. I'll have to look it up but it's something like 9X56 or so?. Blower seals,valve springs and cam follower springs need updating.
CHinNY
12-31-2007 05:06:57
I have a couple of good running engines for sale
buickanddeere
12-30-2007 17:20:37
Any rear fenders, 100rpm pto, float ride seat, 5 speed, live pto, power steering, dual rockshaft, spin out rims? Is the 4" high and 2ft wide cast aluminum piece still there that fits horozontal between the hood and the grill? Is any of the front axle castings busted? Pop the top three bolt cover off the back of the transmission that is just above the pto shaft. Using a strong flashlight, is the ring and/or the pinion gear worn to bits.
