630 0verhaul
fordtech
12-30-2007 13:17:30
Got my engine apart and you guys where right on the top rings were broken cyl leakage was 80%.
can you get pistions from john deere and i would like to put high comp ones in. the bore is standerd the shop manual only shows a .045 over bore but there are larger bore pistions that are avalable,did john deere recomend only .045 max overbore?
F-I-T
12-31-2007 08:49:10
 Re: 630 0verhaul in reply to fordtech, 12-30-2007 13:17:30
Deere only sold .045" over (less in the "H"), but TSC and Central Tractor and the like sold .090" and .125" over in the aftermarket. The YT site here sells .045 and .090 piston sets. Not sure if anyone is offering the .125's any more these days, but there are no doubt some around.
On the over-boring, I'd hate to see you spin out all that extra good bore metal that could be left for the next overhaul, or left for the first guy to slip up during his boring cycle. There has been more than one block that had to go further over because of a mill man slip up, so buy your pistons after the bores are verified. The difference between .045 and .090 is no all that much in terms of volume, and you can probably offset that by good tuning on a dyno, and maybe a dry-type air filter. On the dyno you can get the load adjustment and timing right where you want it, and still retain some good starting characteristics.
P Browning
12-31-2007 03:17:13
A long shot -- but should prove to be a good one -- give Russ a call at (816) 587-4747. He runs the business known for a long time as Paul's Rod & Bearing, AKA Heartland Tractor Parts. Great talent in the engine ara of your tractor and can direct you if he don't have the part. Tell him Pat Browning sent you -- treats you right! (PatB)
Mike M
12-30-2007 17:10:41
I would only go as large as needed to clean it up that way it leaves more options for the future. Should be many aftermarket sources for pistons including this site.
I have never saw a broken ring in the older tractors with cast iron pistons,but boy oh boy those alumumin pistons sure do break them !
