DLTX 71 CARB ?
TIMAR
12-30-2007 09:39:37
I have only seen a couple of 71 gas carbs and everyone has a 1/2 threaded hole right over top the nozzle. Is this supposed to be here? I have not seen mention of it in any parts book.
http://listserv.diytractor.com/Reposts/John-deere-a-dltx-71-gasoline-carburetor/
430WLPG
12-30-2007 19:50:24
 Re: DLTX 71 CARB ? in reply to TIMAR, 12-30-2007 09:39:37
LP gas is the answer to the question, that is where you "spud in" a Lp gas conversion to run on Lpgas , Not to just inject it. Is wasn't done by pullers either . Most were done by Lpgas companies and some JD dealers. In the South and Plains states, Lp gas was 2-3 cents per gallon and gasoline was around 10-12 cents, you can figure out the rest. For years those carbs were looked over by most restorers, because of the hole, but since carbs are becoming in shorter supply they all become more valuable
Mike M
12-30-2007 17:13:59
Must of been a local person who worked on several tractors ,but didn't know how to do it ?
NE IA
12-30-2007 12:23:17
What the hay farmer says is probably correct 99%. The only other option that I can guess is some pullers in the early 70's messed with propane injection. I have seen those, but just can't remember that many years ago. As I think it over it seems it would be simpler to inject LP in other places though. Therefore I'm guessing it may be more like a 99.9% chance someone did not know how to remove a stuck nozzle.
F-I-T
12-30-2007 19:40:39
 Re: DLTX 71 CARB ? in reply to NE IA, 12-30-2007 12:23:17
If it had been on the other side of the throttle plate I'd could have wondered if it was a vacuum port to run the milker...
Looks like a hatchet job for nozzle removal...shame.
Mike M
12-31-2007 06:06:21
 Re: DLTX 71 CARB ? in reply to F-I-T, 12-30-2007 19:40:39
I have had some of those before. I think they may of been put in the intake manifold of the ones I had ? Had a valve with a hose nipple on it.
F-I-T
12-31-2007 07:58:01
 Re: DLTX 71 CARB ? in reply to Mike M, 12-31-2007 06:06:21
Yep. I had one that used a thin plate that was aftermarket, and it served as a spacer between the carb and intake, and the port was there. That way you could remove it if needed.
Mike M
12-31-2007 06:06:16
GeorgiaHayFarmer
12-30-2007 11:15:35
If I had to guess and this is just a guess I would say someone did this to remove a stuck nozzle.
Scott
