4020 Syncro troubles
BigPete
12-30-2007 09:23:11
Have a 1966 lpg with the syncro tranny. The shifting on it is all messed up. Down the whole left side of the shift is supposed to be neutral but it is acting like its in gear. Tow position it is in neutral. I cant get it to go into any of the up gears - 1,2,4,6 and all of the down gears and reverse stall the engine with no tractor movement. I fear that it may have the welded upper shaft that has been described on this forum. (Neighbor borrowed it to auger some wheat, ran out of propane on the road back, and they towed it). I"ve removed the tranny cover to see if the shift forks are okay and they look okay to me. Does anyone offer any advice, experience with this kind of problem. I really dont want to put a lot of money into it as all it is used for is a auger and occasional brush-hogging.
ben brown
12-30-2007 19:53:49
 Re: 4020 Syncro troubles in reply to BigPete, 12-30-2007 09:23:11
i though the same thing and so did they with engine running it would keep it lubed and transmission pump was working. but it still sized. i know that if you pull a deere and its not in tow position it well seize up the top shaft engine running or not, sorta like other day i when my 290 still would run for a while then die out fooled around found the the tank vent was not working right so went to get the part. the owner who is also the parts man tell me thats not the problem. reason, he new, it wasn't the problem he had never sold a tank vent. he had the old type i bough it had him order the new style and lo and behold saws works good now, like i told him even though he had never see it happem before doesent mean it wont.
ben brown
12-30-2007 15:55:45
if they towed it with out puting it in tow then thy sized the gears on the top shaft. even if tractor is running thy well sizes if you tow them. had one couple years ago come in had to replace all the gears on the top shaft and the top shaft.
Bob
12-30-2007 16:04:13
 Re: 4020 Syncro troubles in reply to ben brown, 12-30-2007 15:55:45
HOW fast did they have to tow it with the engine running, to seize the topshaft gears? NEVER herad of that, if the engine was running, and there was oil in the rear end, and, of course, the transmission pump was working!
Bob
12-30-2007 09:55:40
If it was improperly towed, just before the problem occured, you've welded the "low side" gear to the upper shaft. That can happen to the reverse gear, as well, but from your symptoms, it's apparently the low gear.
Third Party Image
The high, low, and reverse gears (4, 13, and 23) should ALL be free of the upper shaft (22), and, if NOT seized, each should be able to be "wiggled" back and forth a bit with your fingers.
BigPete
12-30-2007 12:49:53
 Re: 4020 Syncro troubles in reply to Bob, 12-30-2007 09:55:40
Bob,
Is there any way to knock the gears loose again without a total teardown or are they permanently fused together and time for a new upper shaft?
BigPete
01-01-2008 13:59:15
 Re: 4020 Syncro troubles in reply to BigPete, 12-30-2007 12:49:53
Okay, I had another thought but probably wont try it. Since the low gear has welded itself to the top shaft from improper towing, could it be possible to tow again, heat up the gear where it would turn loose of the shaft, then fire the engine up, say a quick prayer and hope it doesnt stick itself again. Has anyone ever tried this?
