How do you remove the rear wheel/rim on a D
old
12-30-2007 08:53:11
Got this D in yesterday and I need to take off both back wheels so I can put tires on it. Since I don't have a manual and not even sure I can get one how do you pull the wheels off?? If I'm seeing it right you loosen up the lock bolt on the center nut then take it off and then the wheel should slide off. Am I correct on that??
Thanks
Gerald J.
01-01-2008 13:29:19
 Re: How do you remove the rear wheel/rim on a D in reply to old, 12-30-2007 08:53:11
Your tire guy will mount the tires with the rims on the tractor, far easier than with the rims on the ground.
Gerald J.
old
01-01-2008 14:14:18
 Re: How do you remove the rear wheel/rim on a D in reply to Gerald J., 01-01-2008 13:29:19
At $100 plus per tire thats just plain not and option. Plus if I can't get it up and running then that would be a couple hundred down the drain
Ken L.
12-30-2007 10:13:24
Yes you are correct but, I'll bet that it's not going to be quite that easy. I had to make a puller to get the wheels off.
