MT belt drive pulley
Jonathan in MA
12-30-2007 07:21:06
In my quest to lengthen my list of never ending projects, I acquired a 1949 MT that looked like it needed a little TLC... The belt pulley is in good shape other than it has an area that is wider than the majority of the pulley. It looks like it has small rods that pass thru the pulley material and are attached to plates on either side of it, and I'm guessing that one or more of these drifts has broken and caused the varying width of the pulley. I'm not entirely sure of its construction or repair. Have any of you ever performed surgery on the pulley itself? thanks
J. Chantry
12-30-2007 08:02:00
 Re: MT belt drive pulley in reply to Jonathan in MA, 12-30-2007 07:21:06
I recently restored a 49 M with a belt pulley. The belt pulley is made of paper (amazing) held together with steel rods. There was a chunk missing from one side and the owner did not want to pay for a rebuilt one (about $300). He said he would not use it, so I took some wood, cut to fit missing area, glued it in. Then sanded pulley, used some bondo, then painted it flat black. Looked real good.
Jonathan in MA
12-30-2007 12:52:00
 Re: MT belt drive pulley in reply to J. Chantry, 12-30-2007 08:02:00
Thanks... Would you happen to know how the rods are attached to the side pieces? It almost appears that the assembly is compressed and the rods peened over to retain them in the side plates. I heard somewhere they were made of paper...thanks for the confirmation
