Scott, since you asked about Franks tractors Ima guessing youre talking about a pony start diesel correct?? On those and when youre NOT running lights from the ones Ive owned and based on other things Ive picked up Id expect them to charge fairly high for some time right after a start up but after that Im NOT surprised they act more eratic then a gas tractor would cuz as posted below theres such a small load as compared to a gas and that steady 4 amp coil draw that can help stabilize the charging system. From what you said heres about the ONLY thing I would do for now which pretty well agrees with all the otehr good advice. 1) Id clean n polish up the gennys commutator to remove oil or carbon etc and maybe clean n light lube n exercise the brush hold down spring assemblies n insure good brush height remains,,,,, ,,,,, ,,,,2) Id NON abrasively clean/buff/polish the VR's relay contacts,,,,, ,,,,3) Remove n clean n wire brush n shiny n tighten up where the VR gets its ground to the gennys case and you might do a lil cleaning of the gennnys mount to isnure its good ground,,,,, ,,,4) You might look at the batterys cells n insure good electrolyte levels. If she keeps the battery up (and does NOT go over to the - discharge when at decent RPM) I wouldnt mess with it much other then this for now at least and if the VR needs some tweaking its hard to cover that over the net n you may make it worse lol John T (May be headed South tomorrow AM)
