410 WONT MOVE
Tommy Anderson
12-29-2007 19:15:17
Fellas i need some help have a 410-D John Deere backhoe have went through the reverser clutch housing new clutch disks plates seals orings new foward clutch drum the old one was shot new sealing rings the whole nine yards,my problem is i have everything but my foward gears reverse is fine strong but no foward whatsoever im stumped any ideas this is my first backhoe dealings so any help would be appreciated.
Tommy Anderson
12-31-2007 07:23:20
 Re: 410 WONT MOVE in reply to Tommy Anderson, 12-29-2007 19:15:17
Hey Roy it has a solid casting no driveshaft i had the tractor split apart new charge pump rebuilt forward and reverse clutch packs orings seal bearings also replaced forward clutch drum new sealing rings if i broke a ring or if something is bypassing in the foward clutch drum how could i tell i know the broke ring would be easy but what if its by passing in the clutch drum anything i can look for also had the control valve off any ideas on what to check before splitting this mo jo again?
Roy Suomi
12-30-2007 04:48:24
Do we have a 410 or 410-D?? On older 410's the serial number has a "D" directly behind the 410..This designates it was built in Dubuque..Are there solid castings from front to back or is there a driveshaft in there?? Makes a big difference, totally different..Also , did we have the rear clutch assembly out ?? did we take the control valve off??
