JD 4630/4640 15 speed powershift?
JDBrian
12-29-2007 18:25:38
Would it be possible to remove the transmission(housing and all) on a 4630 or 4640 and replace it with a 15 speed powershift transmission from a 50/55 series tractor? Or would I have to replace the transmission and differential as a unit?
bighead
01-01-2008 12:12:36
 Re: JD 4630/4640 15 speed powershift? in reply to JDBrian, 12-29-2007 18:25:38
+1 on everything msb said. You'd be opening a huge can of worms... and would be time and money ahead to either fix what you have, or buy another tractor.
Kevin Schmidt
12-31-2007 09:26:58
I have switched a few tractors over to 8 speed powershift's from syncro's. It really isn't worth the trouble unless the tranny you are replacing has issues. You would have to switch everything behind the engine, also the whole shifter setup in the cab. Probably not cost effective for what a 15 speed will run you.
msb
12-29-2007 21:41:57
Everything behind the engine would have to be changed, not just the transmission . Not sure the block would even bolt up. Not a good idea.Just trade for a 50 or 55 series and get a MUCH better and newer tractor.
