JD 50 electrical question
JDman21
12-29-2007 08:51:30
I put a new ignition switch in and Im not sure I have the wires hooked up right. My tractor did start, but my lights only worked on the 3rd and 4th setting and were bright. My rear light didnt work. Could someone tell me where each wire goes on the switch. My voltage regulator is a 3 terminal and has one wire running to the amp gauge. Is that correct?
Thanks
Jason Z in MO
12-29-2007 20:07:35
 Re: JD 50 electrical question in reply to JDman21, 12-29-2007 08:51:30
Concerning the rear light. I would double check the grounding. The rear light on my 520 is grounded through the float ride seat and was intermittent until I provided a good ground.
GeorgiaHayFarmer
12-30-2007 06:07:24
 Re: JD 50 electrical question in reply to Jason Z in MO, 12-29-2007 20:07:35
Yep,
That's the way the 720 acted so I ran a ground from the seat frame to the battery. Now the lights are working fine. When it comes to lights and grounding issues, if they are suspect, I usually take a jumper wire with a pair of alligator clips and start probing from light shell bare metal to battery negative/positive (whichever flavor ground you have) I have often found when taking the lights apart and cleaning to pay particular attention to the brass strip riveted to the housing and wrap it around the reflector. This in turn provides a good ground to the reflector if the reflector does not have its own separate ground wire. Are you picking up what I'm laying down to ya? Hope you find the problem.
Scott
JDman21
12-29-2007 14:20:50
I replaced the switch because it was very rusted and I thought it might help the light work. My rear light is new. Before changing the switch it worked sometimes. I really didnt have time to mess with it today, but I did get it so all my front light settings are correct.
55 50
12-29-2007 10:08:13
Did the rear light(s) work with the old switch? Is it the dual (white/red combination) type of light? What was the reason for changing to a new switch? (answers to those questions sometimes help others get you the info you need) The diagrams posted by F-I-T are not very easy to read even on the original Service Manual pages so you may not be able to get the needed information from his post.
F-I-T
12-29-2007 10:45:41
 Re: JD 50 electrical question in reply to 55 50, 12-29-2007 10:08:13
They look easy enough to read to me when I save the picture to the desktop and then open at a higher magnification in MS Paint, but the best thing would probably be that I stop bothering everyone with these illegible and inaccurate wiring diagram postings and let you guys provide some better ones.
Frank
55 50
12-31-2007 17:54:36
 Re: JD 50 electrical question in reply to F-I-T, 12-29-2007 10:45:41
Sorry Frank. I didn't mean any disrespect for your postings. They are worthwhile. My problem is that I don't know very well how to express myself in some of these situations and when I read what others get from my postings, I see that I have been a bit off base.
That said, I truly don't get what the guy said who wrote "grow up"! Was that aimed at me or you or who?
F-I-T
12-31-2007 22:23:30
 Re: JD 50 electrical question in reply to 55 50, 12-31-2007 17:54:36
Me.
Anyway, The posting of the schematics from the SM2029 are about all we have to work with since folks seem to be confused with the diagrams in the parts books, which on the whole, I don't see as being too bad. There is a point where you have to just read your way through them, maybe print one out and mark it carefully with different color felt tips. Then you have the SM2029's which are a step up, but they were meant for the more experienced mechanic in mind, and you have to understand what components are not meant for the 70D vs. the 720, etc., and make your own determinations. The problem I have, and this seemed to be one of those cases, where no one was helping the guy, then I post a schematic, then a couple of people come in late and all they seem to do is to shoot out one or two lines which basically say "those schematics aren't worth a hoot", but they don't have anything better to post. That does bite me. If some one has a better picture, then post it, and if you have point by point corrections to it, list them out, but otherwise, it's just a non-productive critique, and it takes far too much time to create a post on my part to take what look like cheap shots. I understand that you didn't think that it sounded like that, but as you can see, others did as well as me. No problem on this end, but all I ask is that if you have something better, post it up! We all need help. Until then, what do we post for people? The -2029's are going to have to do the trick, because I don't see myself scanning my scribbles from the ones I keep in my file. Those are just notes for me and probably wouldn't make any sense to the next guy anyway. But, that said, I would welcome anyone else helping with the posting of photos and illustrations. It takes a lot of time and uses a lot of site space that I could use for other things. I have over 2,000 photos on my picture storing service that I pay to keep up, but someday I'll have to start dropping some of them. It's just getting to be too much overhead.
Have a good New Year!
Frank
Ten-Twenty
12-30-2007 04:06:23
Grow up!!
BLinWMi
12-30-2007 06:33:04
 Re: JD 50 electrical question in reply to Ten-Twenty, 12-30-2007 04:06:23
What the heck, how has your telling someone, apparently F-I-T, to "grow up" helped the situation? Your response is just childish. The way Frank responded to 55 50's comments is completely reasonable. When 55 50 posted, it would have been understandable if he had said that the electrical diagrams were hard to read, meaning interpret. And for those of us, myself very much included who aren't used to looking at things that way, the diagrams can be difficult to follow. But the way 55 50 stated it, I get the idea but surely there was a better way to say it without making it sound like Frank is wasting our time posting the information that no one can read anyways. There has to be a better way to say it to not sound so unappreciative. And then by your great contribution telling FIT to grow up, that has really helped the situation. It wasn't needed or called for. I have had many questions in dealing with these old tractors. I am a farmer, I grow hay and pull teats for a living, I am not an engineer or a theorist. So when I run into something I don't fully comprehend, it is awesome when guys like FIT and John T can pipe in and help explain it and it is wonderful when guys can post a pic or diagram to help me see it on the screen to assist understanding. I asked a question a year or so back about the cylinders on a 45 W, I got some responses but there was only one person who went to the trouble to email me a copy of the pages from the parts book showing the cylinder breakdown, completely unlike B&D's habit of rattling off some 800 number for Deere Publications, instead of helping a guy.
So the way I look at it, I am going to turn your remark back on yourself, Grow Up. I am in great appreciation to the people on here that will go above and beyond, whether it be Glen in TX, FIT, John T, Wilmayb or a host of others that help the rest of us have a greater understanding of the equipment we are using. And in the long run be able to enjoy it even more, to me that seems like a great thing.
F-I-T
12-30-2007 06:26:40
Hwy! How you doin? Boy, there have been quite few technical questions on here lately that could use your help. Jump on in there and put your knowledge to use! I'm sure everyone could benefit from it. Come on! Don't be shy!
Do you have some better wiring diagrams? It would be great of you could poost them. Nice and big and simple to read. There's a fella up the page that needs some 720 charging help. I'd sure appreciate it if you'd handle this one. I know he would, too.
All the best and have a really Happy New Year!
Kurt_JDB
12-29-2007 12:18:54
Frank, I think 55 50 ment that the JD wiring diagrams are often hard to understand for people not reading wiring schematics every day, not that your postings were illegible?
Kurt
John T
12-29-2007 09:19:13
� If its a 3 terminal (BAT ARM FLD) VR YES its BAT terminal wires to the load (NOT battery/starter) side of the ammeter. If its a 4 terminal (BAT ARM FLD LOAD) VR it also has the L terminal wired up to the light switch.
� M Mans Wiring Diagrams has the one which may help or the Frankster may post it direct.
Link
F-I-T
12-29-2007 09:28:29
 Re: JD 50 electrical question in reply to John T, 12-29-2007 09:19:13
third party image
nt
