60 John Deere Wiring
630man
12-28-2007 18:12:12
I am in the process of wiring my John Deere 60. I got a wire harness from mother deere for the generator. It has a white wire that goes to the generator and a green wire that goes to the coil. It also has a brown wire. I dont have a place for the brown wire to go on the switch. Can anybody tell me what the brown wire is for. and if i need it. The tractor s/n is 43755 if that helps at all.
thanks in advance John
630man
12-29-2007 15:42:17
 Re: 60 John Deere Wiring in reply to 630man, 12-28-2007 18:12:12
I dont have a lug on the switch for a ground wire. so i guess i will have to tape up the ends of the brown wire and put it aside.
thanks for the help guys.
John
John T
12-28-2007 19:24:40
� Ive seen different markings on those switches, n you have to have the CORRECT switch. Perhaps it may be labeled MAG or GRND something like that if its indeed the one Frank mentions used to prevent a spark when cranking even when the Ignition is OFF which runs from that switch terminal down to the low (to distributor) side of the coil...
� John T
Tom43
12-28-2007 19:20:52
Unless the 60 is an LP model it doesn't have bypass starting which on gas models began with the 20 series.
55 50
12-29-2007 10:13:28
 Re: 60 John Deere Wiring in reply to Tom43, 12-28-2007 19:20:52
I have a model 50 and it does have the bypass starting if we are talking about the same thing when we say bypass starting.
F-I-T
12-28-2007 19:28:17
It was a field service bulletin advisement and was included in all the wiring harnesses made after that. It's an easy two wires to add to improve starting and as a safe guard. I think the diesel ponies were the first to use by-pass ignition.
John T
12-28-2007 19:26:15
Thats one problem with those darn 2029 wiring diagrams, they had a one size fits all which isnt necessarily correct for alllll ll models.
John T
F-I-T
12-28-2007 19:03:01
third party image
Here's a wiring diagram from the SM02029 and a link. Looks like the Brown comes from the far side of the coil back to the switch to a grounded lug. It's there to prevent the engine starting when cranking, switch off. Otherwise the bypass wire from the starter will power the coil when the foot pedal is depressed. A child or unsuspecting adult could fire the engine just by depressing the pedal if not for that wire.
HTH
Frank
