4010 diesel brake problem
max b
12-28-2007 13:27:50
I recently rebuilt the rear end of a 1961 4010 John Deere. Everything is working except I can not seem to bleed the brakes and they go all the way down. They didn"t do that before I rebuilt the rear end. Any suggestions on bleeding. I tried the book way several times but that doesn"t seem to change anything. Other than the brakes, everything else on the tractor seems to work fine. Hydrolic pump pressure is fine.
rexhellwig
12-28-2007 17:24:04
 Re: 4010 diesel brake problem in reply to max b, 12-28-2007 13:27:50
Behind each bleed screw and jam nut there should be a 3/8ths in. steel ball. These balls are what close the internal passages when the bleeding is completed.
Any chance they got left out?
max b
12-28-2007 17:49:19
 Re: 4010 diesel brake problem in reply to rexhellwig, 12-28-2007 17:24:04
Something to check. Will take the bolts out and make sure they are there. If the balls are stuck in there that would explain why it wasn't bleeding properly. This tractor appears to be all original and most of it has never been taken apart before by the way things look.
Texasmark
12-28-2007 15:54:51
Don't overlook front spindle bushings and toe in. Both make a tremendous difference. Toe in should be about 1/2 inch wider at the back of the front tire than at the front of the front tire. Distance off the ground is best at the axle height. The more slop in your steering system, the bigger this number has to be. BTDT
Mark
Tx Jim
12-29-2007 04:52:53
 Re: 4010 diesel brake problem in reply to Texasmark, 12-28-2007 15:54:51
TexasMark,what manual did you look in to find setting tow-in on a tractor at 1/2 inch? Back when I worked for a JD dealer it was 1/8 inch. Tx Jim
Texasmark
12-29-2007 07:33:05
 Re: 4010 diesel brake problem in reply to Tx Jim, 12-29-2007 04:52:53
I hear you man, but if you noticed I added the caviot "the more the wear, the more the toe" to stop road gear shimmy.
Mark
Gerald J.
12-28-2007 17:11:22
I didn't realize there were brakes on the front wheels and that their function would be affected by front wheel toe in?
Or did this get mis posted?
Gerald J.
Texasmark
12-29-2007 07:34:59
 Re: 4010 diesel brake problem in reply to Gerald J., 12-28-2007 17:11:22
I think it did. I was just wondering what you said myself. So somewhere is a missing reply to a toe in question. Maybe that's where my brake reply is. Grin
Mark
