Generator Update
KB
11-01-2003 18:02:05
Checked out everything and checked all connections and grounds. It appears that the contacts on the VR are pretty well chewed up. The one coil the bring the generator on line was arcing the entire time the contact was supposedly made up. Dressed up the contacts on the VR and everything seems to work just fine. Guess we will get a new one next week. Thanks for your help.
John T
11-01-2003 22:57:25
 Re: Generator Update in reply to KB, 11-01-2003 18:02:05
Youre sure welcome KB, congrats on diagnosing your problem and glad we were of some help. Arcing contacts can carbon up and develop resistance hamperign good voltage regulator action and less than optimum charging. Once they get carboned up bad and you clean/polish/file etc however, the silver coat can be removed and they dont last as long plus may stick or arc again. From your description, it sounded like you meant the cut out relay portion of the VR as opposed to its field control relay was shot right?? Things like brush problems I described in my initial post or an uneven commutator or insulation sections not undercut etc etc plus others can cause VR relay chatter and overswitching causing premature failure, so once you get a new VR be sure other things like the generator (especially brushes and hold downs and commutator)and belt and connections etc are good so you dont harm the new VR. See if the ammeter holds steady or fluctuates rapidly??? if so, troubleshoot the generator before you use the new VR too much.
John T
