HELP!! HAND START 1940 JD B
DURBOBLASTER
12-27-2007 19:22:18
I've been trying to start a '40 JD B following a top end rebuild (Head, valves, bored jugs, new pistons, rings, etc. I choke it until it pops, set the choke at the half way point and roll the flywheel until I'm wore out. I have both de_compression valves open, throttle at half open, idle adj. at 1 turn and load adj. at 1 turn. New plugs, points clean and gapped at 0.015. I have what I believe to be a good spark. The engine will backfire at times and try to take off but seems to only hit one cylinder then nothing. What do I do? On steel, can't pull start.
gtx1967jewison
01-01-2008 18:10:39
 Re: HELP!! HAND START 1940 JD B in reply to DURBOBLASTER, 12-27-2007 19:22:18
I would almost guarantee u the mag is worn on the shaft/bushing. points dont always open at proper time, usually 1 cylinder more than the other, etc. spark looks ok when checked. try a different known good mag i bet it will start right up. had the same trouble/symptoms with a 41" A & tried everything including carb rebuild, many different plugs etc. remove cap & grab the shaft if it moves much at all side to side that"s your problem. sent my mag in to branson ent. rebuilt it hot & now at -10f it starts right up 2nd turn past tdc i never changed anything else! made an entirely new tractor out of it. worth every penny twice over. was $265 with shipping. i use this tractor to move snow in northern ND & if it dont start i cant get to work if it snows. live in country, work in town. remember if its got a mag u get spark on compression & again on top of exhaust stroke in each cyl so u may get popping etc from the second spark (at the beginning of the intake stroke) due to no cylinder pressure so much easier to spark, as when u watch a plug fire out of cylinder. but installed in a pressurized cyl. its much much harder to get a good hot spark, so thats the way it will act. i can flood mine on purpose now till gas runs from the petcock & it starts in 6 or 7 cranks. can crank on it nice n slow now too. when running i can richen it way up till black smoke billows out too & its much more forgiving on the carb settings. sorry so long- hope this helps u. u should b able to start with 1 hand, slowly, with little effort. slightly retarted spark timing helps too so it will never kick back. when the plug fires it starts itself. good luck.
jd b puller
12-29-2007 10:59:56
Did you resolve the spark issue (blue vs. orange). Doesn't that indicate weak spark? Not going to fire under compression.
DURBOBLASTER
12-31-2007 04:59:26
 Re: HELP!! HAND START 1940 JD B in reply to jd b puller, 12-29-2007 10:59:56
JDPOWER,
No resolution on the spark. I have an AP Mag and am now questioning this as the root cause. Will be investigating the cost of a new one r have this one rebuilt.
jd b puller
12-29-2007 05:29:57
You've got a Wico C magneto on there don't you? Something is amiss in there. I'm dumb as dirt when it comes to that kind of stuff.
DURBOBLASTER
12-28-2007 18:35:55
Thanks for all the feedback gents but I couldn't get 'er to hit. I switched wires, checked the timing...at one point she backblowed thru the carb. Going to buy the Autolite plugs tomorrow....frustrating as i think it's close.
If the sparks yellow, what adjustments need to be made to obtain the blue?
dandeere
12-28-2007 06:04:47
Hey Durbo, when you say backfire do you mean flashback through carb. or kick flywheel back? Try her without aircleaner in line. Do the plugs look wet after cranking? Good gas? Try timing again,mag spring snap, and different plugs. You should not have to wear yourself out pulling on them, just kind of tickle em. Those hand starts all have there own personality, but once you find what turns them on the feeling you get from that flywheel jumping out of your hands is close to some other good feelings you get in life!! Good luck, Dan
DURBOBLASTER
12-29-2007 10:26:48
 Re: HELP!! HAND START 1940 JD B in reply to dandeere, 12-28-2007 06:04:47
Still rolling it over. I switched the wires and got an extremely load backfire. At one point it tried to take off but stopped?
Resting Relics 1
12-28-2007 04:54:43
Duroblaster, Sounds to me like your old B is either not timed correctly or you have the wires crossed. Recheck that your on top dead and when it fires it's the same left side plug. One thing the B is known for is their ease in starting if their even close on adjustments. John
Mike M
12-28-2007 04:15:34
Far better than pull starting is to hook another tractor to it by a flat belt on the pulley.
CalJim
12-27-2007 21:56:15
What kind of plugs do you have ? I rebuilt a 36 B, went for a month of hard starting, replaced the Champion plugs with Autolites and now she starts on the first pull most times. Maybe its just me, but .015 seems a little tight for a gap. CalJim
DURBOBLASTER
12-29-2007 10:28:09
 Re: HELP!! HAND START 1940 JD B in reply to CalJim, 12-27-2007 21:56:15
I bought Autolites this morning and they didn't help. Still tweaking!
John T
12-27-2007 20:04:48
This can be caused by several things n its late so I will just toss out a few items. If she always backfired badly n popped n banged n maybe kicked the flywheel backwards Id think it was 180 out of time in which case a plug wire swap would cure it if it were a direct drive mag like a Wico C or X, but you talk like its hitting on one n not the second cylinder so dont sound like its that 180 out popping banging backfiring thing for now.
1) Try the throttle at just a slow idle NOT half open.
2) Try the load needle about 3/4 to 1 turn out and 1 1/2 to 2 out for the idle needle.
3) Adjust the start impulse timing to make darn sure the mag snaps right at TDC i.e. when the flywheels Left Hand Impulse timing mark is in the 3 o clock position lined up with the flat index mark on the tractors side. If too fast she may kick the flywheel backwards but if too slow she can be hard to start.
4) Have good clean fresh dry plugs, clean n gapped points, wire core plug wires.
5) Test for a good strong visible BLUE and NOT a faint thin wimpy yellow spark.
6) DO NOT OVERCHOKE N WET FOUL THE PLUGS. You ought to see some gas vapor out the petcocks n not raw gas. Are the plugs dry or wet or what if she dont start n you pull n look at them.
7) Try removign the plugs n squirt a lil oil in the cylinder n turn her over a lil to oil seal up the rings for more compression then insert plugs n try her.
Timing at TDC,,,,, ,,hot blue spark,,,,, carb adjusted right and set at slow idle,,,,, ,,clean fresh dry plugs,,,,, ,,wire core plug wires,,,,, ,dont overchoke n flood..... .
I will check with ya tomorrow, good luck
John T
DURBOBLASTER
12-29-2007 10:33:34
 Re: HELP!! HAND START 1940 JD B in reply to John T, 12-27-2007 20:04:48
John T,
I tried everything you suggested, it did try to start at one point but didn't keep turning over?
Ordered some hot Autolite plugs from NAPA due in on Wed.
DURBOBLASTER
12-29-2007 10:33:26
John T,
old
12-27-2007 19:40:29
First off why can't you pull start it?? I have a 1935 JD-B on steel I pull start once in a while when it has sat a long time and it never is a problem to do that. Now then, on my B I open the trottle all the way, choke it but I don't spin it over I rock the flywheel forward and back 4 or 5 times till I here a hiss sound. Then I unchoke it all the way and pull it over. Most of the time when its warm it will fire right up. This time of year I don't even try to start it because it has 50W oil in it so I can't turn it over very well
DURBOBLASTER
12-29-2007 10:35:36
 Re: HELP!! HAND START 1940 JD B in reply to old, 12-27-2007 19:40:29
The yard is too wet this time of year...I don't have another belt drive tractor to follow thru with that recommendation. 30W oil in this one still rolling over ok at 34 degrees today but won't start.
RobMD
12-27-2007 19:44:29
50 weight oil? Must smoke quite a bit if you put 30 wt in it! LOL.
old
12-27-2007 20:13:38
 Re: HELP!! HAND START 1940 JD B in reply to RobMD, 12-27-2007 19:44:29
Well its been in my family since 1940 and as far as we know the head has never been off of it. Plus the owners manual says to run 50W oil in it in the summer and thats the only time of the year I do run this old B I have. But yes it does smoke a good bit but as long as it still runs ok and doesn't foul out the plugs I'll not open it up to re do the rings etc. Who else can say they have a tractor with factory rings in it being that old.
Mike M
12-28-2007 04:14:27
 Re: HELP!! HAND START 1940 JD B in reply to old, 12-27-2007 20:13:38
I once had one of those same B's that was so easy to start it never took more than 2 turns and you were off.Smoked like heck and blew oil drops all over everything. This was just how I bought it. Amazing how well it started and ran ! Sold it the same way. I think the new owner found out it had a wrist pin tore up one cylinder ?
