john deere 1941 engine
bert gagnon
12-27-2007 18:45:41
I have an early 1941 John Deere B tarator and it is totally taken apart. The cylinders are .450 over nominal 4.5. The later model B for the same year cylinders are 4.687. Can I bore these cylinders and sleeve them or do I have to start from new.
machinery-man
12-28-2007 06:34:51
 Re: john deere 1941 engine in reply to bert gagnon, 12-27-2007 18:45:41
Personally I would stay away from as much machine work as possible. I"ve always taken blocks with considerable wear, as long as they clean up and remove the burr from the top of holes have never had any problems. No more than these old tractors will be used, a ring job, tightening rods should last many years.
Mike M
12-27-2007 18:55:10
Well you have several options. Someone may make .090" oversized pistons for the 4 1/2" bore. Vendors in Greenmagazine may be a source. You can always sleeve it. How bad are yours worn ? maybe just hone and new rings will be fine ? NOS blocks can still be found for those. You might have enough metal to bore to 4 11/16 late B gas pistons. I have heard of several of these being done back in the day when they were used.
Mike M
12-27-2007 18:55:01
