First of all, these tractors used gear oil in the steering box originally. However, fast forward about 50 years, and you have a tractor that is worn out. The steering shaft gets worn both at the top and the bottom bushing points. Often, replacing the bushings does nothing for taking out the slack. SO instead of rebuilding the shaft up to spec, they decided to prevent leakage by using grease gun grease in the gear box. This worked well, and is still used in the tractor world as a viable alternative. Thus, with a completion of a steering box rebuild, I like to use a synthetic grease, such as John Deere corn head grease in the gear box. This stuff is rather sticky and clingy, but MOST OF ALL, it does NOT liquify like regular grease gun grease under high temperatures (which leads to a NASTY NASTY front end dribble on your fresh paint, lol). Now, IF you put that 140 weight oil in it without new seals, it will just dribble down the shaft and make a holy mess. If you use grease, I would just leave it in there until you can rebuild the box and use JD corn head grease.
