JD 1945 H
Dan Sp
12-27-2007 11:50:59
Have a 45 H has been o/h run great only for one problem when engine is under full load and lugging it wants to back fire thur intake manifold it's not a fuel problem more like cam or timing has any have had this happen to them idles and starts great 1/4 turn doesn't matter cold or hot?
Hoss in Maine
12-27-2007 16:18:28
 Re: JD 1945 H in reply to Dan Sp, 12-27-2007 11:50:59
Hey guys ,could valve lash be too tight? Wondering, Hoss
Mike M
12-27-2007 12:12:19
Are you positive it isn't a fuel problem as in being too lean ? Can you open up the load screw and make it smoke black while doing this ? I have seen carbs.( rebuilt by others ) that did not have sealant applied to the brass plugs that sucked air in by the plugs cause alot of fits too.
You can check the cam timing by using the LH EXH mark on the fylwheel. Valve cover off valves all adjusted turn the fylwheel to where that mark lines up with the mark at 3 o-clock on the tran. case the LH EXH valve rocker should just have all free play gone at or within 1" of that mark. If not the cam may be in wrong or severly worn.
Dan Sp
12-27-2007 13:24:45
 Re: JD 1945 H in reply to Mike M, 12-27-2007 12:12:19
Thanks for the ideas I don't think it is the carb we switch one from known good tractor and it did the same thing.But it is either lean which we but propane under load and still back fired I will ck the valve timing it will take a couple of days and I will get back with you
