JD 2010 power steering/hydraulic problems
CRaig Chaney
12-27-2007 08:24:20
JD 2010 hydraulics work fine no or little power steering. Looking of a pump or a rebuild older serial # casting #t16691t. Used one rebuilt is fine but needs to be working. Any other sugestions. Beleive the part # is AT14932, HELP
jdemaris
12-27-2007 10:37:37
 Re: JD 2010 power steering/hydraulic problems in reply to CRaig Chaney, 12-27-2007 08:24:20
What type of 2010 do you have and which hydraulics are still working?
I ask because we sold several 2010 wheel-loaders that had front-mounted engine-driven Webster or Cessna gear-pumps for the loader hydraulics and a large, belly-mounted gear-pump that ran the power steering (which we had many problems with).
Bob
12-27-2007 10:31:04
If you have hydraulics, but no STEERING, it sounds like the flow divider may be bad, or there's a problem with th steering unit itself.
The rest of the system should NOT be getting oil until the steering flow needs are met.
BEFORE shelling out big bucks for a pump, you need to get a flowrater and a pressure gauge on it, as shown in the service manual, and be verify where the problem lies... pump/flow divider or the steering gear/valve/steering "motor".
