7700 powershift transmission
JDBrian
12-27-2007 08:19:47
How reliable is the powershift transmission in a John Deere 7700 tractor?
powertech84
12-28-2007 18:20:00
 Re: 7700 powershift transmission in reply to JDBrian, 12-27-2007 08:19:47
reprogramming, or "recalibration" as deere calls it, is nothing more than letting the computer run through shifting procedures and learning the the specifics of each shift down to the millisecond. not hard, but only dealerships know how to do it.usually its best done every couple thousand hours.
powertech84
12-27-2007 16:04:09
they're not as bad as alot of people make them out to be sometimes. like any electrically shifted transmission they do have to be calibrated everyonce in a while to keep it shifting comfortably. midway through the 10 series they switched from digital to analog shift valves and this made a big difference in shift quality. if they're maintained correctly, they can last a long time
TD
12-27-2007 09:24:49
I would consider the PowerQuad. The 76-7800 series had some trouble with the Powershift, most of them that I saw had problems with the electronic end, customers would have to bring the tractor in every couple of yrs just to reprogram it. The 10 series were pretty much trouble free, and to step back to the good old 55 series with the 15 spd, they were a bullet proof transmission all the way thru.
JDBrian
12-28-2007 17:57:04
 Re: 7700 powershift transmission in reply to TD, 12-27-2007 09:24:49
What is involved in "reprograming" the transmission and how expensive can this be? How often does this have to be done? I will only be using the tractor for about 100 to 200 hours per year.
