John Deere M hand crank specs
Brendon Nafzige
02-04-2000 17:22:07
I am wanting to make a hand crank for my JD "M" and am needing to know some dimensions of the original crank. The only measurements that I can not easily get without taking stuff apart are the length and diameter of the cross pin that engages the fan pulley. I am planning to use a roll pin for this purpose. Thanks in advance.
Steamer
02-07-2000 12:20:26
 Re: John Deere M hand crank specs in reply to Brendon Nafziger, 02-04-2000 17:22:07
I actually have a hand crank laying around somewhere. It came with the old 420C, but we've never used it. Like the others have said: It's Not A Good Idea! I have used it to set TDC on these series of machine after they've been torn down, but that's all I'll ever use it for!
RonMC
02-05-2000 18:25:03
Thanks guys - I have an M and a MC, and was thinking of finding a crank, but will save the effort now. Don't really need serious bodily damage.
Virgil
02-05-2000 08:38:19
If you never had a broken arm, dislocated shoulder, cracked ribs, etc. ,then the need for such is great, then try using a crank on the M or MT. There is no way to retard spark, like a Model T car, with out moving the distributor. A crank for them is just for looks. My Dad use to start our MT with the crank in cold weather, and very seldom would work. Keep your engine tuned and battery charged. Self preservation of body. They kick like a mule and then some. I have a crank around somewhere and wouldn't sell, give, or lend it to my worst enemy!!! Only good for setting timing WITH the spark plugs out.
BIG EMMITT
08-12-2003 19:44:49
 Re: Re: John Deere M hand crank specs in reply to Virgil, 02-05-2000 08:38:19
SON ,YOU SOUND LIKE MY KINDA MAN GOOD ADVICE
Z-bar
02-04-2000 22:53:34
Brendon, I don't know the specs on the crank, but I do know that you dont want to hand crank them. you cant retard the timing, and when you crank it, it will kick back. i saw my dad hand crank a 40 one time, never forget how far that crank went. but luck if you decide to make one.
