Tommy, congratulations for obtaining your �H�. They�re fun little tractors, and a lot easier to work on compared to their big brothers (like the A or G, for example). First, a little correction. Your serial number, 10115, is actually considered a 1940 model. Serial number 9999 was the last 1939 model, and 10000 was the first 1940 model. The serial number list in this website, found in the links in the left margin, under the heading of �Research & Info�, then under the link �Serial Numbers�, then link to �John Deere�, then finally linking to �H�, shows an old list that isn�t correct. Furthermore, the stated location of the serial plate (�The Serial Number is located on right side, on the top of the frame�) is wrong. In fact, there were two locations for the serial plate. For serial numbers less than 27000, the location was on the left side of the main case, near the top, and slightly behind the flywheel. For 27000 and later units, the serial plate was on the right side of the main case, near the front top corner, and in front of the clutch/belt pulley. Be aware that Deere never published a �service manual� for the H. The early owners manuals (called �Instructions and Parts Lists�) contained a listing of parts but without diagrams. And those IPL�s contained considerable maintenance information. However, later versions dropped the parts data and eliminated a lot of service information for work once done on the farm that was subsequently considered best done at the dealership. For example, valve grinding and piston ring replacement instructions were originally provided in the early IPL�s, but omitted from later editions. As others have mentioned, you really need a parts manual, still available from Deere. And Pat Browning�s Restoration Guide contains lots of good information and data. Pat also has compiled a service manual for the H that contains a lot of the information found scattered throughout the I&T manuals and other sources of maintenance information and data. Go through the motor anyway? Well, it depends on your definition of �restored�. Some would say that a restoration must include a total and complete rebuild/replacement of any wear items (bearings, shafts, gears, etc.) back to original specifications. Others think that a �drive-by painting� is good enough to call it a �restoration�, and are tolerant of a little extra noise, smoke, and leaks. Personally, I agree with Mike M below. Do what is necessary to get it running, and then make a decision about the need for more in-depth work based on the results from making observations and tests after it has been made to run.
