1010 starting
mark
11-01-2003 17:47:05
i have a jd 1010rs that can sometimes be contrary to start, but even on it's good days it only starts when i let off the key. is this normal? Also, can i replace the generator with an automotive type alternator? are there any special considerations?
Thanks! mark
JB
11-02-2003 17:03:18
 Re: 1010 starting in reply to mark, 11-01-2003 17:47:05
Hi, it has been over 30 years since I worked on a 1010 but I do remember something about a resistor connected to the coil from the run switch.
I found this in the archives concerning switching to electronic ignition and restistor or resistive pink wire:
It dosen't make any difference where the pick up is located in the distributer, although you may have to turn the distributer slightly to get the exact timing. The units I have seen you have to switch to negative ground, the negative terminal of the coil goes to the distributer. The hot wire of the pick up has to be hooked to the switch side of the resistor. There were some changes in the wireing over the years. If yours has a pink wire, it is a resistor wire. Some had a ceramic resistor. You don't need both the pink wire, and the ceramic resistor.
JB
JB
11-02-2003 08:15:30
Hi, does your 1010 have a 12V system with a ballast resistor in series with the coil ?
The way this is suppose to work is when the start switch is engaged the full 12v is applied to the coil to give a better starting spark but when the start switch is released and in the run position the ballast resistor is in series with the coil to drop the voltage and extend the life of coil and pionts.
Now if your 1010 starts when you release the start switch to run position, is there 12v to the coil when in the start position ?
I have also seen this problem when the spark timming is misadjusted.
Hope this helps
JB
Loren
11-02-2003 09:49:39
 Re: Re: 1010 starting in reply to JB, 11-02-2003 08:15:30
What you said is interesting. Where is this resistor physically located on the tractor? If it was the problem, why would Mark's tractor start only when he let off the starter? Are you saying that whatever the voltage is in the run mode, his might be even less in the start mode? This is a new concept to me and I would like to know more.
JP
11-03-2003 05:10:12
 Re: Re: Re: 1010 starting in reply to Loren, 11-02-2003 09:49:39
This would imply the resistor is broken - open. Tractor starts while winding down from cranking when switch is let return to 'run' position. This is pretty good if it catches in the short time winding down; if resistor circuit is fixed it should start very easily.
mark
11-04-2003 09:08:48
 Re: Re: Re: Re: 1010 starting in reply to JP, 11-03-2003 05:10:12
thanks everyone for the replies! JP,what is involved in fixing the resistor circut?
mark
Loren
11-02-2003 02:51:05
No, I wouldn't say your starting experience is normal. I have had problems with my 1010 but when I get the carb and ignition system right it works right. Have you tried cleaning the carb and replacing the plugs, points, condenser, rotor and distributor cap? Incidentally, 1010s have a fuel filter that fits inside the carb inlet. Mine plugged and gave me fits for a long time before I figured out what was wrong. You might want to check that while you are working on it. The filter is metal, so you can clean it out and resuse it.
I still have the generator on mine, so can't address the swap to an alternator.
