70 gas questions
super99
12-27-2007 04:48:12
I am in the process of overhauling my 70. Local auto parts/ machine shop can get pistons, rings and pins for $185/hole, and bore out block for $150 to $175. I am going to try to get the block out today and get it into them to make sure its OK before they order parts. Should I take out the oil pump and check it over? When I got it, it didn't have much oil pressure and there is a screw that I turned in and got lots of oil pressure. Also the flywheel side of crank is leaking oil around the seal I need to replace it before I put new taperlock flywheel on. What about crankshaft bearings? How do you check for wear or excessive play? I am not interested in a better than new rebuild, I just want it to run so I can use it on 65 acres to spray and maybe pull 4 row planter. Since I'm in this far, what should I be checking or replacing to avoid more problems down the line? I tried to look in the archives, but all I get are a lot of numbers and can't seem to find specifics on this. Thanks in advance for any and all help, hope you all had a great Christmas. Chris
F-I-T
12-27-2007 08:28:05
 Re: 70 gas questions in reply to super99, 12-27-2007 04:48:12
Wrist pin bushings. Seldom checked, less often replaced, really makes a difference in noise level.
buickanddeere
12-27-2007 06:39:50
The camshaft and followers get tired as well after 50+ years of service. They may look ok to the eye but they will be worn enough to put the valves out of time. As you are in this far, this is the time to true them up or wish you had. Where are you finding new pistons/rings/pins for that price? As the factory compression was only 6.15 to 1. It's free HP and improved fuel efficiency to run the 7.3 to 1 LP pistons. Don't worry, it won't knock. This would also be the time for fresh valve guides and hardened exhaust valve seats for unleaded fuel. You need the service manual from 1-800-522-7448. It will keep you from making mistakes and having the pleasure of doing the job over again. It maybe a simple old engine but torques and clearances are vital. Some barnyard tinkerer having already ruined the flywheel and crank splines is proof of that. Flywheel end play is a hotly debated topic but being closer to 10 thou is better than 5 thou. There is a bushing in the distributer that costs only a few bucks but will make or break the tractor's operation. If you can feel any wiggle in the rotor shaft, she needs a bushing. Otherwise ignition timing will wander and the engine even miss as the point gap varies. As previously stated, oil pressure over 12 to 15+ psi will push oil past the main bearings. If somebody is running th engine without a thermostat at less than 180F and it should really be 195F to properly burn the fuel. High rates of cylinder wall and bearing wear will occur along with a tendency to soot up the engine. The mating surfaces of the manifolds and the cylinder head have to be perfectly flat and not eroded/corroded. They each may need a few thou milled off to true them up. Any manifold leaks at all and the engine will not idle correctly and it will draw dirt into the engine. The paper gasket will not take up gaps on the intake and it will blow out on the exhaust. After the exhaust burns through it can blow onto the intake gasket and burn it through too. Setting the fan drive shaft clearances are vital. Too much and they are noisy, too little and "crunch".
BLinWMi
12-27-2007 05:55:10
Chris, as long as you are getting in it that far, do you have the instruments to measure the journals? When I did my 70, I had to replace the crank as some clown had welded the flywheel on, so I took the new crank and the main bearing supports to a shop and had them measured and new mains pressed in. Chances are if yours is worn enough to need the block bored, it probably has some excess slop in the main bearings. And since these tractors are known for cracking flywheels, I would want to keep the crank from flopping around even the smallest amount.
rickdeere
12-27-2007 05:49:58
your tractor should have no more than 15 Ibs of oil pressure at high rpm. its a high volume pump with a low pressure pump,this can make a seal leak if its to high,get a master gauge on it and check it out.the oil pump is fine. a high reading guage is not going to work.Get a book that tells you how to work on your tractor and read it.If you need a tappered flywheel sounds like your crank is shot anyways on the flywheel side, the splines should be good and sharp and have no play when you put the flywheel on, never run your tractor with a loose flywheel and make sure its on in time.Take play out of flywheel think only should allow form 2000-5000 end play, its in the book read it .good luck,
Mike M
12-27-2007 05:05:58
You can check those mains by placing a dial indicator on the crank and then see how much up and down play it has.
