A batteries
MTC
12-26-2007 19:03:36
Hey guys- looking at a 1949 John Deere A to buy.What should I look for? Tractor has not ran for 3 years.Needs batteries--2 six Volt? Any advice would be appreciated.Thanks and hope your new year is a good one.Mike
johns48jdb
12-27-2007 05:01:42
 Re: A batteries in reply to MTC, 12-26-2007 19:03:36
you need to drain the oil and check the water level in the radiator of course. draining the oil will let you know if the block is cracked. you might just check the oil and see if any water runs out. if its been sitting the long expect some water to come out but shouldn't be much. don't turn it over until you check this first. i'd remove the plugs and squirt a little oil in there and probably try to pull start the tractor to start with or at least disable it in some way to keep it from firing and turn it over a lot to get oil back in every thing like it should be. i'd drain all the old gas out and put in fresh with some gas stabilizer and stp gas treatment in it too. drain all the gas out of the carb too.
buickanddeere
12-26-2007 22:02:53
Don't waste time and effort bolting the chassis cable to the battery box. Get a longer cable and bolt it directly to a casting. Is the coil's + terminal connected to the distributer or to the ignition switch?
F-I-T
12-27-2007 05:57:33
 Re: A batteries in reply to buickanddeere, 12-26-2007 22:02:53
third party image
I know I improved the cranking on my VAC Case by taking the ground cable and bolting it directly to the starter mount. I figured it had a shorter path from cable to cable to that way.
Frank
Andy Motteberg
12-26-2007 20:37:14
Use a large 12 volt or two 6 volts.
F-I-T
12-26-2007 19:12:09
Like Mike says, any good size single 12 volt unit should do. Back in the day, there were no BIG 12 volt batteries, so they opted for two sixes in series. Today, you can get a 1,000 CCA or better in any number of fair priced 12 volt batteries. If you plan on operating on rough ground, get one with a plate frame built for that. Lately, the OPTIMA brand gel cells are my favorites. Maintenance free, never leak, high output, and very rugged.
Frank
Mike Aylward
12-26-2007 19:28:20
 Re: A batteries in reply to F-I-T, 12-26-2007 19:12:09
Frank, perhaps you know this but I thought I would pass it along in case you didn't. I have an Optima in my pulling tractor and had to have it replaced. The place I bought it (Auto Zone) told me to never use any kind of booster charger on this type of battery as it will burn them up. I didn't know this until it was too late. They warranteed the battery but told me to be careful with boost. They like a slow, steady charge and won't stand boosting. Hope this helps. Mike
John T
12-27-2007 05:40:12
 Re: A batteries in reply to Mike Aylward, 12-26-2007 19:28:20
Mike, I mentioned this subject to Frank before, Ive read some material that talks about how the Optimas are pretty sensitive to the charging voltage n current and arent that well suited to the old generator systems but work better with an alternator. If I dont feel lazy someday (when may that be lol) Ima gonna have to research that subject, unless you want to lol
When we gonna meet up at another show??? I will be on my best (usual) behavior at GOG, the first wifes retired as of yesterday n will accompany me to help lay out my clothes n darn my socks etc
John T
Mike Aylward
12-27-2007 14:21:38
 Re: A batteries in reply to John T, 12-27-2007 05:40:12
John, I am planning on going to GOG and dang it, I'm going to spend more than one day there. Just need to get the reservations made. That way I can harass the most people possible in the least amount of time..:) Hope to see you and others there. Mike
F-I-T
12-27-2007 05:54:32
I never had a problem related to charging on either the cut out system on the VAC or the VR system on the 70D.
F-I-T
12-26-2007 19:41:23
Well, I would have probably imagined that to be so because you have to use the same precautions with gel cell types that we used for field days/emergency tests on ham radio equipment. I use a "Battery Tender" smart charger if I have to charge one. I like those because I can put it on and leave for the week and take it off when I finally get back to it. I don't have anything that "boosts" these days. Used it up on my early electrolysis trials years ago.
Frank
GeorgiaHayFarmer
12-27-2007 15:40:54
 Re: A batteries in reply to F-I-T, 12-26-2007 19:41:23
Hey FIT,
What is your call? Are you active on any of the HF bands? If so, shoot me an email. I have a General class ticket and am set up for HF. I work a fellow down near Charleston SC on 60 meters and 40 every once in a while.
73,
KF4DDJ
F-I-T
12-27-2007 16:19:52
 Re: A batteries in reply to GeorgiaHayFarmer, 12-27-2007 15:40:54
Call is WB8ENS/4. Haven't been "active" on HF for years, but I do get my Icom 735 out down at the barn now and again and copy some CW. I always used wire antennas on HF up in Ohio, but down here I'm thinking of putting up a nice vertical, and running some radials with my trencher so I can stilll run the grain drill around it. I yack on an HT in LA when I'm there during the week. I need to hook with the JPL club since I'm out there during the week. Porbably be a while before I'm on HF. Too many projects around the QTH.
73's
GeorgiaHayFarmer
12-27-2007 18:33:23
 Re: A batteries in reply to F-I-T, 12-27-2007 16:19:52
FIT,
The Icom 735 is a good one. That is what I use on HF with an auto tuner and a G5RV at about 45 feet. It was my first HF rig and a keeper. I built a couple of CW transmitters and receivers and enjoy listening to CW when I have time which isn't very often.
F-I-T
12-27-2007 19:48:46
 Re: A batteries in reply to GeorgiaHayFarmer, 12-27-2007 18:33:23
That was my first new HF rig. Assembled some Heathkits, but I never thought that htose counted as "new". :)
I also built a fair number of "Tuna Tin 2's" and Altoids receivers. Worked a fair amount of DX on QRP. Just no time these days. I travel 5 days a week coast to coast. I kept my license current because I see that as one of my fall back hobbies when I have to give up working in the shop.
Mike M
12-26-2007 19:05:34
Just grab 1 good sized 12 volt.
